Old 19th April 2009, 07:00 PM   #1
Default Help identifying a loudspeaker
A few days ago i listened to a pair of DIY loudspeakers that look like the attached drawing.
Can someone help me identify those? They were playing very well, I was impressed.
They were about 40” high.
Old 19th April 2009, 07:21 PM   #2
It is difficult to identify them from the drawing. They may be simple sealed boxes on a stand. But if the rear view shows a hole at the base they may be tranmission lines. Can you post a photo of them? That would be the most helpful thing to do.
"It was the Spring time of the year when aunt calls to aunt like mastodons across the frozen waste." P.G. Wodehouse.
Old 19th April 2009, 07:36 PM   #3
Hi Jonathan
Thanks for your reply.
Unfortunately i live far away from the place where I heard them, besides I don’t know the guy, and the drawing is by memory only.
They were not sealed box. In fact I remember they had in the back a square port that was vertical (strange for me), it seems that the port (as large as the box, and firing down) was made with a piece of wood that was internal but paralleled with the back cover of the box. I remember also the guy telling me the middle range and tweeter share the same (small) inner space. And the bottom of the box was filled with sand (lowest 10”) and allocates the XO.
Old 19th April 2009, 07:41 PM   #4
Visualy the main caracteristic was that the front wood panel that allocates the drivers was larger than the box itself and i don't know if this detail was for esthetical reason or other reason.
DIY loudspeaker vs. factory built loudspeaker keyser Multi-Way 83 16th May 2011 12:27 PM
Help Identifying Cap..... dmongrain Parts 13 1st June 2009 03:20 AM
Help in identifying ST OP AMP packer Parts 3 8th July 2007 09:21 PM
I need help Identifying these nblimfark Multi-Way 0 13th November 2006 02:27 AM
Identifying a cap... EchoWars Parts 4 27th August 2006 10:43 PM
Page generated in 0.08815 seconds (75.09% PHP - 24.91% MySQL) with 11 queries
