Old 19th April 2009, 12:53 AM   #1
Default SPL and excursion
I have no idea how to solve this sort of problem, so I'm falling back on you guys. This is not homework, by the way.
An acoustically-small driver that fires into half-space plays a full-spectrum sound (that is, equal energy at all frequencies between 20 Hz and 20 kHz) but is 4th-order L-R bandpassed at 150 Hz and 600 Hz. The C-weighted (flat) SPL at 1 m is measured to be 110 dB. What is the peak-to-peak excursion of the driver?
Old 19th April 2009, 04:49 AM   #2
Brett's Avatar
Model the particular driver in Unibox and look at the Xcurs curve.
Here is a curve for the required volume displacement for a given spl and freq. Extrapolate to fit your requirements.
Old 19th April 2009, 05:24 AM   #3
I can do that with either WinISD or SL's spl_max spreadsheet, but AFAIK the numbers are only valid for single tones. Any given SPL that is comprised of various frequencies should have less amplitude per freq, right?
Old 19th April 2009, 06:07 AM   #4
Brett's Avatar
Did you bother to look at and think about the above graph?
For a given SPL the LF requirements dominate xcurs.
Old 19th April 2009, 06:39 AM   #5
Fine. What is the error of the calculated excursion when assuming a single tone at the lowest reproduced frequency? At what low-pass point does this error become excessive?
Old 19th April 2009, 08:58 AM   #6
Brett's Avatar
What the graph shows is the calculated amount (volume) of air needed to be displaced at a given frequency to produce a certain SPL. HOW you do that is irrelevant. How much error between a measured result for a given driver and the calculated will depend upon the driver and it's linearity. That you need to MEASURE.
Old 19th April 2009, 01:29 PM   #7
Ron E is offline Ron E  United States
Ron E's Avatar
Modeling the loudspeaker as a linear system, superposition holds.
The excursion is the vector sum of the excursions at each frequency. I know of no analytic expression for noise, or music, so you will have to approximate it by brute force.
You could start at 20Hz and go up at 1/12 octave intervals.
Our species needs, and deserves, a citizenry with minds wide awake and a basic understanding of how the world works. --Carl Sagan
Science is a way of thinking much more than it is a body of knowledge. --Carl Sagan
Old 19th April 2009, 09:50 PM   #8
Sorry, I believe you misunderstand me.
Thanks, Ron. Too bad, eh? Is the total SPL based on the total excursion, then?
Old 19th April 2009, 11:25 PM   #9
Ron E's Avatar
Don't get me wrong, There are a number of ways to approximate this.
The simplest is to calculate the excursion at each frequency and add them up.
The excursion at F1 = X1
Excursion at time t, due to F1 = X1*sin(2*pi*F1*t)
Do this for every frequency...This is brute force.
You could also generate a model and apply a stimulus.
For your example, you have the added complexity of a bandpass filter.
I could do this, but not for free, what is it worth to you to know the answer?
Old 19th April 2009, 11:37 PM   #10
Do I sum the SPLs from each frequency individually, then?
Right now? Absolutely nothing.
How much excursion is too much? scott_jcp Subwoofers 11 13th October 2009 05:56 PM
OB vs BR: driver excursion bvan Full Range 5 13th January 2009 07:20 PM
Too much excursion! with no watts no less!!! xstephanx Full Range 18 24th March 2007 02:37 PM
Q: what does 46mm of excursion look like? A: like this ..... paulspencer Multi-Way 46 17th February 2006 07:49 AM
Page generated in 0.10861 seconds (80.67% PHP - 19.33% MySQL) with 11 queries
