Old 18th April 2009, 05:12 AM   #1
Cool 4 6.5" in a row
Hello all,
I am looking at building a floor stander with 4 x L18RNX/P. Has anyone tried this? I am assuming there will be issues with lobing?
Old 18th April 2009, 05:29 AM   #2
badman is offline badman  United States
Custom Title
badman's Avatar
Try making a big, wide baffle, with the four L18s positioned around a central midtweeter (fostex FF85k comes to mind) with a relatively low (500Hz) XO. Don't use a line, but an X-shaped array.
Should work fine
I write for www.enjoythemusic.com in the DIY section. You may find yourself getting a preview of a project in-progress. Be warned!
What makes an amplifier "bright", "warm", or "neutral"? JohnS Solid State 51 13th December 2009 06:42 PM
Charcoal "Supreem" hi-density foam "enclosure" IG81 Multi-Way 0 23rd April 2009 01:34 PM
What Does Fostex "Rated Input" and "Music Power" mark02131 Full Range 3 2nd January 2007 08:31 PM
Some final pics of "Stacks" revisited and "Askew" with stand Andy G Multi-Way 2 3rd February 2005 06:07 AM
Anyone used Scan-Speak's "Flow Resistors" or "Aperiodic Vents"? Ignite Multi-Way 3 18th November 2001 08:42 AM
Page generated in 0.07033 seconds (68.20% PHP - 31.80% MySQL) with 10 queries
