Old 17th April 2009, 03:08 PM   #1
jkeny is offline jkeny  Ireland
Banned
Default New Flat Speakers Developed
Warwick University have developed a flat speaker - I don't know how it differs from the NEXT flat speaker panels but may be f interest to those here http://www2.warwick.ac.uk/newsandeve...205e116e1d7a35
And here: http://www.warwickaudiotech.com/
Old 17th April 2009, 03:31 PM   #2
chrisb is offline chrisb  Canada
bloody interesting indeed
you don't really believe everything you think, do you?
community sites t-linespeakers.org, frugal-horn.com commercial site planet10-HiFi
Old 17th April 2009, 04:02 PM   #3
soongsc is offline soongsc  Taiwan
soongsc's Avatar
No mentioning of bandwidth data, hard to beleive it'll look good.
Hear the real thing!
Old 17th April 2009, 04:05 PM   #4
scott wurcer's Avatar
I like the description of the first prototypes. There are mass and displacement issues and it's not even clear what is the motive technique. 1000's of Volts?
2012, our time is running out.
Old 17th April 2009, 04:38 PM   #5
tvi is offline tvi  Australia
tvi's Avatar
Electrostatic audio loudspeakers US patent 7095864.html
"An electrostatic transducer, such as a loudspeaker or microphone, comprises a multi-layer panel (1) incorporating an electrically insulating middle layer (2) sandwiched between first and second electrically conducting outer layers (3, 4). At least one of the layers has a profiled surface (6) where it contacts the surface of another of the layers. Furthermore a signal generator is provided for applying an alternating electrical voltage across the first and second layers (3, 4) to initiate vibration due to variation of the electrostatic forces acting between the layers, thereby serving as a loudspeaker (or for detecting variation of such electrostatic forces due to received vibration in the case of a microphone). Such a transducer can serve as a low cost audio loudspeaker which can be made lightweight and flexible so as to render it suitable for a wide range of applications, for example to provide sound reproduction in a home environment without requiring any bulky enclosure, or in a notebook computer or mobile telephone."
James
The border between the Real and the unreal is not fixed, but just marks the last place where rival gangs of shamans fought each other to a standstill. Robert Anton Wilson
Old 17th April 2009, 05:21 PM   #6
Thanks for that. In 1969 I built David B. Weems' "wild woofer" and CTS had some electrostatic tweeters (exactly as pictured in the patent) for $1 or so each in their catalog. A thin sandwich of felt and some gold sputtered film, I never got the transformer to make them work but the "data sheet" had pictured directly rectified 220 mains as a bias supply.
They use 200V because they are so thin but doesn't that mean the displacement is small? SY?
Old 17th April 2009, 05:27 PM   #7
frugal-phile(tm)
planet10's Avatar
Here is the other thread, same subject
New technology from the UK
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 17th April 2009, 06:52 PM   #8
gedlee is offline gedlee  United States
Its a good idea. I've long wondered why electro-statics weren't done this way. Its simply an electro-static membrane on a fixed set of substrates. Usually one wants the restoring force to be just the tension in the membrane but thats not necessary. HOWEVER, the efficiency is directly dependent on the stiffness of the insulator and an insulator HAS TO BE stiffer than air. Hence, I'm betting that the resulting transducers are very inefficient. But of course this can be made up for by size. But size is cost and cost is limiting. SO in the end you have just another way to do an electrostatic loudspeaker, but its the same size and cost of its predecessors - no big gains.
Old 17th April 2009, 11:18 PM   #9
jamikl is offline jamikl  Australia
Does this have relevance to the discussion going on about biased capacitors in crossovers in the thread of that name?
jamikl
Old 18th April 2009, 10:28 PM   #10
Planet10:
Thanks for linking across to the thread I started in ESLs/alternative
Ed
BoSoZ has developed a hum after 4 years... HooRide Pass Labs 12 10th January 2008 12:18 AM
New flat panel speakers. Ap Multi-Way 0 31st March 2004 12:20 AM
flat panel speakers Mr Hayes Multi-Way 1 26th November 2003 05:25 PM
Flat Panel Speakers (any good?) bobcat190 Multi-Way 12 26th November 2003 04:38 AM
NTX Flat Panel speakers Iceshack Multi-Way 2 9th February 2003 10:15 PM
Page generated in 0.09947 seconds (79.48% PHP - 20.52% MySQL) with 10 queries
