I'm new into speaker building. Are there any specialized router bits for plywood routing? Can I used regular router bits?
#2 |
Custom Title
As far as I know, you use the same bits regardless of what (normal) material you use. Keep them clean, oil the bearings, and sharp.
You definitely want the biggest bevel(chamfer) and/or roundover bits you can get (and your router can swing), as well as a flush trim bit and a spiral upcut bit. Rabbeting bits are also helpful for cutting driver recesses and doing joinery, though it's usually better to cut the recess with a circle jig at the same time you do the driver through-hole. Do the recess first then adjust inward and do the through-hole. Take care when the circle falls not to lose control.
I write for www.enjoythemusic.com in the DIY section. You may find yourself getting a preview of a project in-progress. Be warned! |
#3 |
Some issues with technique when routing plywood:
1) Take precautions against tearout at EVERY corner. Remember that the plies alternate orientation. 2) Do not use bits with an aggressive convex profile. They may tear the plies apart.
Aerodynamics are for people who can't build engines. Enzo Ferrari |
#4 | |
The scrap also helps a bit in controlling splintering. (I learned this the hard way.) Also, spiral bits are definitely smoother cutting- both in wood and in your wallet. Cheers John |
#5 | |
HSS (steel) bits (from the olden days) will not last long cutting the glue lines in plywood. Cheers John |
#6 |
John is correct, the glue used in plywood is very abrasive and will dull lines in a steel bit fairly quickly. MDF in its make up is glue and dust thus it to will dull steel tooling fairly quickly also. Quality carbide bits and blades are your best choice not only for composite materials but for all around quality, in all materials.
#7 |
Down cutting solid carbide spiral bit to cut driver recess holes. ¼ inch diameter will do fine and will work with Jasper jig. I'd stay away from HSS bits. Carbide tipped bits aren't much more $, safer to use and will last longer. Carbide can also be resharpened a few times.
#8 |
I use Whiteside solid carbide bits. They received the highest rating in a test done by a woodworking magazine. They have the least tear out and last the longest.
Any technology sufficiently advanced is indistinguishable from magic |
#9 |
I cannot stress rough cutting when all possible to keep the bits happy...
I personaly use whiteside or amana bits... |
#10 |
Very useful info. Thanks a lot!
| Do I need a router? | curiousburke | Multi-Way | 36 | 9th December 2007 01:18 PM |
| CNC Router | Dryseals | Multi-Way | 11 | 7th November 2006 03:01 PM |
| Need Router help | xyrium | Multi-Way | 18 | 22nd July 2006 10:17 PM |
| What to look for in a router? | flaevor | The Lounge | 8 | 14th January 2006 05:35 PM |
| Router problem? | gchrist | Multi-Way | 11 | 3rd September 2003 01:03 AM |
| Page generated in 0.11778 seconds (82.57% PHP - 17.43% MySQL) with 10 queries |
