I have the following drivers
Vifa P21WO-39-08 Audax TW034XO My wish are to build a pair of Sealed 2 way speakers with a volume of 1-1,25 cuft. But, The Vifa`s dont seem to be offering the kind of frequenzy response needed too do this with a simple x over. So i wonder, will removing the dustcap and adding a brass phaseplug clean up the 1khz-3khz area on and off axis without adding other difficult artifacts? I have also seen that some manifacturers use Copper or Aluminium caps or rings in the polepiece area to reduce distortion (and maybe also induktion) Would a brass phase plug also help with this? Questions basically boils down to this. can the results of such a modifikation even be predikted, or are measurements the only way to even get close to real world specs |
| Phase Plug, how does it works? | Antonio | Multi-Way | 5 | 17th June 2009 12:05 PM |
| Phase plug seems to make a new BSC necessary. | G | Full Range | 3 | 28th March 2008 06:05 PM |
| Phase Plug Dims ? | valveitude | Full Range | 0 | 16th November 2006 03:10 PM |
| Anywhere to buy off-the shelf phase plug? | bcherry | Full Range | 6 | 19th October 2005 07:22 AM |
| Phase plug question | mrfeedback | Multi-Way | 4 | 2nd May 2002 01:41 AM |
| Page generated in 0.05433 seconds (66.35% PHP - 33.65% MySQL) with 10 queries |
