Old 15th April 2009, 10:51 AM   #1
mrevie is offline mrevie  Australia
Default High Pass Crossover for FE87E (Protection)
I recently purchased a pair of Fostex FE87E fullrange drivers to use in a pair of rear surround speakers. Having done some reading, I've discovered that it's a good idea to prevent significant amounts of bass from being passed to the driver to prevent too large an xmax damaging it. Seeing as it's not practical for me to use a digital/electronic crossover in this isntance I need to design a passive crossover to do the job.
I've decided to go for a second order linkwitz-riley as I feel it offers the best medium between too slow a rolloff and too sharp. Ideally, I'd like the cutoff frequency (-3db point) for this arrangement to be about 200Hz. If I were to use a higher order crossover then I'd want it about 150-180. The measured impedance of the driver at ~200Hz is around 12 Ohms.
When calculating the values for the components I discover them to be:
Cap - 33uF
Coil - 19mH
Now, 19mH seems a somewhat ridiculous value for an inductor in terms of cost and size. So I decided to play with the value a little bit in simulation. Lowering the inductance of the coil to 4.7mH (a much more reasonable level in my opininon) doesn't seem to have a negative effect on the simulated crossover.
Are there any drawbacks to using the smaller inductor? Is there a better way to achieve what I want without using a passive HP filter?
Old 15th April 2009, 11:26 AM   #2
ttan98 is offline ttan98  Australia
I bought a similar pair from Ebay as well, I suppose they from the same seller.
I mounted them on a small cabinet, for such a small speakers they throw a quite a sound stage. SOund good too will improve with time.
Good buy.
Old 15th April 2009, 11:30 AM   #3
Yeah, looking at the data on them they do look quite nice for surrounds. I was considering using them in a semi-omnidirectional rig, purely because they'll mostly be used for effects.
Mine will most likely be mounted in a sealed enclosure with a max volume of about 5L.
Did you use any form of crossover to protect it from too much bass?
Old 15th April 2009, 12:17 PM   #4
I use an active x-over.
YOu can use active x-over or even design passive x-over at line level.
Old 15th April 2009, 03:23 PM   #5
frugal-phile(tm)
planet10's Avatar
Getting a passive XO to work on these at the frequency you want is an extremely difficult job since you are working just above the impedance peak.
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 15th April 2009, 03:47 PM   #6
I have a similar question. For a 24db biamped oct xover at 215hz could you put this driver ( fs 140, qts .92 ) in an enclosure so it's fs is 215hz and qts is 1.4 . Then feed it's amp from
a 12db xover with a Q of .5 so the sum of the 2 xover sloaps
come out to a Q of .7 and 24 db octive?
Old 15th April 2009, 09:25 PM   #7
Any suggestions on how to improve the passive crossover that I want? Going active really isn't an option for me.
Old 15th April 2009, 09:32 PM   #8
This is the response get when simulating
Old 15th April 2009, 09:34 PM   #9
From this circuit
DIY Low Pass and Mid/High Pass (Bass Blocking) Filters runslikealpaca Everything Else 1 19th June 2009 10:59 PM
high pass filter (crossover) derekyu Multi-Way 8 30th March 2007 05:32 PM
Need High level, high pass crossover for 250watts Anthrax Multi-Way 0 21st January 2007 03:34 AM
high pass crossover - active, passive, simple or complex? nick78 Parts 1 23rd May 2006 06:43 AM
high gain 2nd order high pass active filter topology sreten Solid State 21 23rd March 2006 01:26 AM
Page generated in 0.09844 seconds (76.92% PHP - 23.08% MySQL) with 11 queries
