To wall mount or not?
Old 14th April 2009, 04:52 PM   #1
bikelectro is offline bikelectro  United Kingdom
Default To wall mount or not?
Hi Folks,
Just looking for some advice. I'm currently using a pair of Castle trent 2's on rigid floor stands. These are a compact 2 way design with front reflex port, they are on a modest Creek CAS 4040 and give good tight tunefull bass despite the wooden suspended floor in my 15 by 15 foot room. I am soon going to rearange the room and to make more space and hopefully improve the sound, i wander about wall mounting, has anyone any ideas? If so i want to know about the most rigid brackets to buy as they will be going on a proper brick wall. I hope to maybe even improve the already great performance from these compact speakers i've had for 15 years. I used to always think wall mounting was a no-no, but maybe i'm wrong. Had my floor been concrete as in my last house, i would probably keep them on these stands as they are very solid.
Old 15th April 2009, 07:17 AM   #2
Shaun is offline Shaun  South Africa
Shaun's Avatar
Hi bikelectro
How far from the wall do you have them now? You could move your stands such that the speakers are flat against the wall. This will give you an indication of how they'll sound when mounted there. You get boundary reinforcement from the wall in the lower frequencies; the effect changes with distance from the wall. See here.
Shaun Onverwacht
|||||||||| DON'T PANIC ||||||||||
Old 16th April 2009, 01:42 PM   #3
Thanks for that!, interesting reading. At present they are in front of a bay window, so no parallel wall behind them. Where they are going is at both sides of a sort of alcove formed by a chimney breast, i.e.;- one speaker will be on the outside corner of the breast and the other in a simialr outside corner although not right angled formed by the bay window. They sound good now, and again they will be about at least 1 foot from the back of the alcove and have no parallel surface realy behind them. But , as you say, when i do the room i will try them first on the stands. I think it will be ok, so will just want to know what are the best sturdy brackets to support small compact wooden cabinets, as i cannot get to examine them anywhere before i buy. If they sound good in the new position on the stands, i'm hoping for an improvement with them firmly wall-mounted, also to free the floor space and have them a bit higher up.
Cheers, again for your advice.
To wall mount or not?Hide this!Advertise here!
Designing for on-wall/near-wall speaker placement morbo Multi-Way 4 27th November 2010 04:52 PM
zaph slimline wall mount blue934 Multi-Way 4 17th May 2007 02:05 PM
in-wall/on-wall speaker? (axiom w-22 clone?) Scott_fx Multi-Way 0 22nd February 2007 02:08 AM
WT: OPA2604 Surface Mount 2x - Will trade DIP mount 2x Destroyer OS Swap Meet 1 22nd December 2006 06:18 AM
Opinions on wall to wall subwoofer array jmiyake Subwoofers 35 19th July 2003 11:26 PM
