Speaker for ROCK
Speaker for ROCK
Old 4th June 2009, 07:42 PM   #81
Cal Weldon is offline Cal Weldon  Canada
Speakerholic
Cal Weldon's Avatar
Speaker for ROCK
Glad to help. Selenium tweeters are known around the world but the woofers don't get as much attention. The ones I own have surprised me.
planet10 needs your help:
Let's help Ruth and Dave
Old 5th June 2009, 12:59 AM   #82
901Fixer is offline 901Fixer  United States
The enclosure design PE lists for the 15PW3 is 6 cu.ft. with two 4" diameter port tubes, 1.58" long. My plan for the box is rectangular 21" wide x 48" tall x 11" deep. The driver will mount on the front 21" wide baffle at the very top edge so as to be close to the mid in the 901 and the vents will be at the bottom as close to the floor as possible. Is there anything wrong with these dimensions? Offset the woofer left or right some? I'll also run a vertical holey brace from top to bottom to support the driver, baffle and rear panel.
I think I've found a source for Baltic Birch close to me so 3/4" is what I'll use. Double the thickness of the baffle? Recess the driver into the baffle?
Old 5th June 2009, 05:59 AM   #83
454Casull is offline 454Casull  Canada
MJL, do you remember the hole diameter for the 15" drivers?
Old 11th June 2009, 02:45 AM   #84
e_fortier is offline e_fortier  Canada
e_fortier's Avatar
Speaker for ROCK
Since I started that thread I wanted to tell you where I was at with this project.
I finally decided to built a 3 way without pro-drivers. The drivers will be ; Woofer : Peerless 850146, the mid : TB W5-704D and the tweet Dayton ND20FA-6
Just like here I got some great help from the Quebec Audio Video web site, here is the link in the DIY section.
http://www.quebecaudio.com/forums/in...5&#entry243742
Best regards,
Eric
Speaker for ROCKHide this!Advertise here!
Rock - Progressive Rock ->>> Rixsta Music 118 10th December 2012 09:00 PM
Rock with a full range speaker type Full Range 20 1st July 2006 04:48 AM
Best DIY Speaker for Rock Agisthos Multi-Way 77 15th September 2005 09:06 AM
nedd a speaker setupo for rock and vocals Konnan101 Multi-Way 3 24th December 2003 03:42 PM
What makes a *great* rock speaker? leadbelly Multi-Way 51 6th August 2003 01:13 PM
