I am trying to sort out the impedance of my speakers. If I hook two drivers in series to raise the impedance does that mean they will also be out of phase since the positive of one is hooked to the negative of the other
#2 |
Speakerholic
No that is fine. It's a series connection on an AC circuit.
#3 |
Thank you
#4 |
so you may wish to put the first in series to the bottom
#5 |
How so?? is it the resistance of the first driver?
I know the series connection can effect the Qts of the following driver but wasn't aware that power sharing changed. regards Ted
QUOTE" The more I know, the more I know, I know (insert maniacal laugh >here<) NOTHING" |
#6 |
thus causing a voltage drop to the second, that is why you can have two 4 ohm speakers in series for around 8 ohms impedance, you can shift the load slightly to about 55/45 by redirecting a small amount around but you will never be able to 50/50, but you will loose a little power be supplied to the speakers
#7 |
frugal-phile(tm)
It is an AC signal... there is no 1st driver. you will get a voltage divider that is based on the actual impedance of the speakers. If they have identical impedance each driver gets 50% of the signal.
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#8 |
Hi mcmahon48,
Look at this another way. You have a series circuit. Therefore the current flowing through one speaker must be the same as the current flowing through the other speaker. It does not matter which one is closest to the positive phase or common (negative phase) terminals. The power dissipated (used up) in each speaker will depend on the exact impedance ratio between them at each moment in time. This means that one, then the other plays louder depending on their impedances at each frequency - and the temperature of each voice coils as they heat up. Sound confusing? Too many details. So, if they are each rated at 4 ohms, you will have a total of an 8 ohm load. Each speaker will get 1/2 the total power. Make any sense now? -Chris
"Just because you can, doesn't mean you should" © my Wife |
#9 |
I have always wanted to hook up a pair of identical 4 ohm magnepan speakers in series to see how it would sound, and get 8 ohm impedance...crazy to think such a thing? Anyone done this before?
I have ans love my MGIIIa's, and always have an eye out for another pair to "make" myself a Typmani type maggies by connecting them in series.
"I speak Spanish to God, Italian to Women, French to Men, and German to my Horse" - Charles V |
#10 |
Hi John,
I'm thinking the ability of the amplifier to control the panels would be severely comprised. Running your Maggies off a single pair of network cable would begin to show the effects. Actually doing this would expose more complications as the impedance changed with frequency. Probably better than running a couple pairs of speakers that had complex crossovers and impedance. Go ahead an try running one channel that way. -Chris
| Does having two amplifiers hooked into the same pair of speakers cause any problems? | The Paulinator | Multi-Way | 19 | 3rd April 2004 04:38 PM |
| Logitech Z-series speakers use TB drivers? | coolkhoa | Multi-Way | 12 | 12th March 2004 11:54 PM |
| Is a series-XO the only way to always have both speakers in phase? | Bricolo | Multi-Way | 11 | 31st March 2003 08:40 AM |
| Efficiency of Two Speakers in Series | markkanof | Multi-Way | 17 | 2nd May 2002 06:37 AM |
| Page generated in 0.10782 seconds (78.77% PHP - 21.23% MySQL) with 10 queries |
