Old 20th October 2009, 08:19 PM   #231
StigErik's Avatar
Originally Posted by mige0 View Post
LOL
(you don't have to use rubber - no good!)
Oh yes, there are situations where rubber is no good.
Old 20th October 2009, 08:42 PM   #232
Rudolf is online now Rudolf  Germany
Rudolf's Avatar
Another example of a stringed WOB (WithOut Baffle )
Xovers are at 100Hz and 1500Hz with 24dB/oct. Bass EQ is 20 dB total from 100-15 Hz. Mid EQ is 15 dB total from 450-100 Hz.
The builder reported that there is almost no movement of the Kilomax when hung from the ceiling.
www.dipolplus.de
Old 21st October 2009, 01:57 AM   #233
CLS is offline CLS  Taiwan
Wow! that's a quick action, and wonderful, too!
In such 'suspension', I found the compliance in the tensional direction is not necessary. By the relatively low mass and low rigidity, the vibration energy can not pass through the suspension effectively. So any string/wire/cable can be used if only the tensional strength is enough. (I myself use stranded steel wire with clips for hanging my mid-high horns)
Old 21st October 2009, 05:58 AM   #234
mige0 is offline mige0  Austria
mige0's Avatar
Location: Austria, at a beautiful place right in the heart of the Alps.
...I myself use stranded steel wire ...
Me too - I found it the best sounding, cheap and most reliable solution.
I recommend to pay attention to some details - there is some reward of.
Make sure you have well defined points where the most part of movement (bending) occurs - meaning - avoid any rubbing there (the internal friction is already something we can not avoid).
Michael
Old 21st October 2009, 07:54 AM   #235
StigErik's Avatar
I am very tempted to try the same with the woofer as well. I am a bit unsure whether such a heavy woofer (370 grams cone) with large Xmax will stay in place without any support. Just have to test it I guess. Will need a much heavier frame than I have now, but we'll see.
Old 21st October 2009, 08:52 AM   #236
I got a center OB sub which the construction is very shallow, accommondating 2 18" with 130g Mms (total 260g). When playing, its vibration is quite obvious by touch.
OTOH, my main baffle is more rigidly braced and with deeper base board. And with only one woofer (same as above), it's much calmer by comparison.
I think, baffle-less or not, these heavy woofers would better be braced/supported rigidly to obtain better dynamic and output. Suspended freely, there'd be inevitably opposite motion (or some forms of delayed and irregular motions... ) on the whole driver related to the cone.
Old 21st October 2009, 09:48 AM   #237
StigErik's Avatar
CLS,
Like I suspected... thanks.
Think I'll go for a heavy bracket or something for the woofer.
Old 21st October 2009, 11:21 AM   #238
mige0's Avatar
Regarding irregular motion - that's what I too thought before I dived into the topic – but actually quite the contrary is true. Try and you well see - aahhh - you will hear
If you read through my paper (math is pretty simple) you can see that "movement in disorder" only happens with the common approach eg. trying to keep speakers rigidly in place – whereas suspending a speaker freely results in absolute predictable movement of veeeeery low amount.
http://members.aon.at/kinotechnik/di...ducing_CIC.htm
The net benefit is that there is *no* resonance whatsoever (except the veeeery low fundamental of the pendulum) when speakers are hung – well - for the overall movement we are talking of here.
Seen from a more philosophically point of view my arguments outlined in the paper directly relate on the concept of "local mass" – which can be seen as an equivalent to "acoustically small dimensions".
Michael
Old 21st October 2009, 11:50 AM   #239
Rudolf's Avatar
Thats what the user of that Kilomax reported: There was NEVER a visible motion of the woofer basket and magnet.
Regardless it helps to make the pendulum as long as possible.
www.dipolplus.de
Old 21st October 2009, 11:56 AM   #240
Hmmm.... can't imagine now, but I'll try to understand. Thanks a lot
For those drivers already installed on the baffle, what can be done? It seems all gaskets/spacers are not compliant enough. And it's hard to 'float' the whole assmebled baffle
open baffle bass-dipole-what amp felixx Multi-Way 20 13th December 2006 07:53 AM
Open baffle/ dipole design help Infinity buff Multi-Way 3 12th April 2006 03:19 AM
New Open Baffle Dipole Pics PaulHilgeman Multi-Way 25 27th April 2004 04:43 PM
Beyma (or other modest priced) drivers for a open baffle project. swak Multi-Way 2 22nd November 2003 08:59 AM
Page generated in 0.12805 seconds (78.32% PHP - 21.68% MySQL) with 11 queries
