in Madisound .Any of you rich guys is playing with "the exotica" ??
#2 |
Difficult to seriously consider ordering them when i don't get the madisound X2-08/t-35 vented box plans. They looked promising for low watt set's due to a higher sensitivity then their exotic fullrange driver but the supplied box plan shows bass dropping off below 500Hz. The X2-08 almost mirrors the factory measurements from 500Hz down.
I like the "idea" of a easy to place high WAF, 94db 2-way "smaller" than the adv. comparable size fullrange driver/BLH, for a change of flavors if these can do that. So, can anyone here take the time to run a box simulation to see what the bass response could look like in a larger vented enclosure? Also any reason why a Audax TW025A26 or TW025A28 couldn't be used to get the ball rolling and then upgrade to the exotic T35 at a latter point if you fell the need to? http://www.madisound.com/catalog/PDF..._exotic-w8.pdf |
#3 |
A lot of the drop off you're seeing with regards to bass roll off, isn't the bass at all.
The way SEAS measure includes bafflestep - that is to say they measure speakers in boxes, rather then huge 'infinite' baffles.
What the hell are you screamin' for? Every five minutes there's a bomb or somethin'! I'm leavin! bzzzz! Droggon Attack! |
#4 |
now you're confusing me and i don't get it. are you saying that the box plan provided will be relatively 94db out to a 80hz or so roll-off? or for that matter that a F8-X1-08 will be 93db till roll off in the rec. 60L. sealed box because that's not what their plot is showing in the plot of it in a 60L. sealed box dotted line, see pdf brochure SEAS Exotic X1-08, F8, 8 ohm, 8" Full Range Driver from Madisound
#5 | |
What I am saying is that above bafflestep you will have a 94dB speaker. Then as wavelength increases with decreasing frequency, the baffle width starts to become insignificant with respect to the wave. Due to this you get a 'step' (more like a 'slope' in reality because the transition isn't instant) occurring, where you lose 6dB of output as the radiation of sound goes from hemispherical to radiating in a complete sphere. To compensate for this you pad down the highs. The reality is that a 94dB loudspeaker, measured on an infinite baffle, will end up being an 88dB speaker. At a guess the dotted line SEAS draws represents a real world sensitivity, after baffle step has been compensated for. (You don't typically need 6dB, this figure depends on room placement and to a lesser degree drive unit itself) So really you're going to end up with a ~91dB loudspeaker. Usually SEAS overlays the dotted line above the bafflestep transition. But from looking at several data sheets it appears that the placement is sometimes done at random.
| Sealed enclosure for SEAS Exotic | johnsonad | Full Range | 58 | 9th October 2011 08:14 PM |
| Seas Exotic Pricing | Arc | Full Range | 68 | 23rd November 2010 10:05 PM |
| New Seas Exotic drivers | bambadoo | Multi-Way | 21 | 28th September 2010 08:50 PM |
| Sealed box SEAS Exotic vs. Lowther RLH | davidross | Multi-Way | 0 | 10th April 2009 05:55 PM |
| What happenned to SEAS Exotic? | anubisgrau | Full Range | 6 | 17th June 2008 09:49 AM |
| Page generated in 0.07731 seconds (78.45% PHP - 21.55% MySQL) with 10 queries |
