Current drive for speakers - diyAudio
Old 6th April 2009, 07:16 AM   #1
Default Current drive for speakers
Sorry to bring up this old topic, but I've been thinking (again, my apologies). Does current drive really help out with power compression? It doesn't make speakers behave like they do with voltage drive, but that doesn't necessarily mean that current drive is perfect. We know that joule heating causes the voice coil to heat up, which means that unless the conductor is made of constantan or a similar material, the resistance will go up. This means that current drive does the opposite that voltage drive does - it'll put more power into a hot voice coil.
This should also apply to inductance effects. It should be safe to say that varying inductance (impedance) causes distortion by modulating the voltage. As before, instead of fixing the power to the speaker, current drive will do the opposite thing that voltage drive does.
So why did Hawksford measure a decrease in distortion by using current drive?
http://www.essex.ac.uk/dces/research...nt%20drive.pdf
EDIT: You can use constantan for voice coils. You just lose about 10dB of efficiency compared to copper.
Old 6th April 2009, 03:53 PM   #2
DougL is offline DougL  United States
I apologize for the lack of a more rigorous answer, but my intuition is to model a driver as a zero resistance coil in series with a resistor. Further, current through the coil is proportional to electromagnetic force.
In the case of constant voltage, as the resistor heats, the current and EMF decrease. In a constant current situation, EMF is constant. The resistor does receive additional heating.
Similar logic works for the inductive component of the voice coil.
The 20 DB reduction makes sense to me. I assume that other mechanical non-linear systems such as surrounds prevent a more dramatic reduction in distortion.
Doug
Scienta sine ars nihil est - Science without Art is nothing. (Implies the converse as well)
Mater tua criceta fuit, et pater tuo redoluit bacarum sambucus
Old 6th April 2009, 08:16 PM   #3
Doug
Yes, but isn't the acoustic power proportional to the electrical power?
Old 6th April 2009, 11:15 PM   #4
I think that is the point, that the resistive heat loss is dynamic and adds nothing to the acoustic output. So power is not proportional to output. Current is proportional to output.
Doug
Old 7th April 2009, 12:38 AM   #5
Doug
I'm still stuck at this point. Are you saying that acoustic power is derived from the coil current ONLY and has nothing whatsoever to do with the electrical power through the coil?
Old 7th April 2009, 01:27 AM   #6
Mr Evil is offline Mr Evil  United Kingdom
It's possible to work it out from a few simple equations:
i * Bl = f
f / m = a
v = int(a)dt
f * v = P
therefore
P = i * Bl * int(i * Bl / m)dt
(do please point out if I've made a mistake!)
where
i = current through voice coil
Bl = force factor
f = force on cone
m = moving mass
a = acceleration
P = instantaneous power
Note that there is no relationship to the electrical power wasted in the voice coil resistance.
EDIT: Oops, calculus.
https://mrevil.asvachin.eu/
Old 7th April 2009, 03:18 AM   #7
Mr Evil
Well said.
Doug
Old 7th April 2009, 03:38 AM   #8
That clears everything up for me. Thanks!
Old 7th April 2009, 06:27 AM   #9
Wait, why does output go up near resonance?
Old 7th April 2009, 12:11 PM   #10
That calculation only shows the total mechanical power applied transferred to the cone - some more of it will be lost before it finally emerges as sound power e.g. losses through damping in the surround. Those losses vary with frequency.
Current Drive Power Amp lumanauw Solid State 11 2nd March 2015 02:31 PM
Bridged current-drive amp? annex666 Analog Line Level 7 3rd June 2008 04:21 PM
Drive current for MOSFet's ifrythings Power Supplies 5 19th May 2006 08:36 PM
mix current drive with voltage drive at LF? capslock Multi-Way 0 27th April 2006 11:17 AM
Copyright 1999-2017 diyAudio
