Old 5th April 2009, 09:35 AM   #1
Default Woofer to make Seas Excel duo three way?
I have millennium tweeters and excel 7" magnesium woofers that I'd like to build a three way with. Can anyone suggest a woofer that will work well with my excels to make it a three way?Obviously there are many drivers that will work, but Im thinking of something will blend well tonally and has at least the same power handling or more than my combo and is considered as uncoloured/transparent/detailed as the excels. Size or number of drivers dont matter.
Not too worried about a complete design at this stage. I'll be tri-amping with digital XO so Im hoping I can wing it then tweak.
Old 5th April 2009, 11:10 AM   #2
RIP
Hi Joe,
I'm definately not an expert but I have BR MTMs with those drivers. The 7" Excels would not be a good choice for mid drivers in a three way, they have extreme breakup nodes right in the area where you would normally cross over to the tweeter. May I suggest a 2 way crossed around 2k and a sub crossed around 40hz if you feel the need. Personally I could knock the windows out of my house with the 7" Excels I have now. I have two 10" Peerless subs that I quit using when I built the MTMs, no need for them except maybe home theater.
Bill
Old 5th April 2009, 12:02 PM   #3
Bill,
You are correct, not the ideal mid driver, usually. I didn't tell the whole story cos I didn't want to be told it cant be done But...
I have pair of passive two way near field monitors with the excels that are perfect, except for the early bass roll off. I have two 12"XXLS subs but I don't like crossing higher than 70 to the subs so this leaves a 'hole' around 100Hz that the 7" cant fill. So I'd like to try ditching the subs and rolling off the 7" around 250Hz and crossing to say a 10" or pair of 8"s. The way I hear it, the monitor works very well. It's just a case adding to the bottom end. Unconventional I know, but I've been itching to try it.
Do you find you overload your BR's soon as there's a hint of sub 50 bass? It doesn't take much to max out my 7" and mine are sealed. Forget about movies with these.
Old 5th April 2009, 12:51 PM   #4
RIP
Hi Joe'
I see, you might want to try decreasing the volume of your cabs, if the xmax is the problem, the drivers are becoming unloaded. From memory, they should be less than .5 cuft. The hole in the response is almost definately from baffle step loss. Martin King has a simple circuit he uses personally with his home setups for BSC, I'll attach it if I can find it.
My BRs are tuned to about 30hz so that allows for room gain and they have never become unloaded. I've not come close to xmax and I would guess they go down to 25hz reasonably flat in room response. I took a lot of measurements when I built them but measuring bass in room is very difficult.
I drive them with a Pass Aleph 5 [75W], great match.
Bill
Old 5th April 2009, 05:06 PM   #5
What's the budget?
Old 6th April 2009, 02:38 AM   #6
454Casull,
I'd be prepared to pay US$350 per side to have a go, more if I was certain I would work. I'll find a use for the drivers if they dont suit anyhow.
What have you in mind?
Old 6th April 2009, 03:31 AM   #7
http://www.aespeakers.com/drivers.php?driver_id=13
http://www.bcspeakers.com/product.php?id=0000000068
http://www.bcspeakers.com/product.php?id=0000000052
What types of enclosures can you put the drivers in?
Looking some Seas Woofer to make my HT Subwoofer. samsagaz Subwoofers 11 8th June 2008 01:37 PM
Seas Excel W15 & W22 cdoggy81 Swap Meet 7 19th December 2006 01:47 AM
WTB: Seas Excel mazeroth Swap Meet 0 30th June 2006 05:35 AM
Eton 12 inch woofer/Hiquphon/Morel/accuton/seas excel M15 mmm12dna Swap Meet 2 29th December 2005 09:51 PM
Seas Excel W26 compaired to Seas L26 (10") harruharru Subwoofers 9 11th March 2005 09:47 PM
Page generated in 0.10216 seconds (85.60% PHP - 14.40% MySQL) with 11 queries
