Old 5th April 2009, 12:15 AM   #1
morfic is offline morfic  United States
Default Plugin to help with xover point + attenuation
I usually don't use any plugins since they all to me cause trouble more than they help. Having said that i think i could use one to help me figure out attenuation of my tweeter.
I am looking for a plugin that unlike an EQ only has a single frequency and a dB slider, if i knew what you would call that, i'd google it.
It would let me set the frequency to say 3500Hz which is my current xover point, and drop everything above 3500Hz up to say -12dB. I;d like to get an idea if i want a simple attenuation or if i want to attenuate after moving the xover point.
The coarse steps of EQs don't seem practical, especially if i am not sure how wide or narrow they affect the frequencies and if they stop well below 20khz. (although they did give me the idea that i'm on the right track, they are just not suitable to test my xover point moving idea)
If someone knows of any such plugin for winamp/foobar/mediamonkey/* you could make a audio geek a happy man today, so don't wait!
Thanks,
Daniel
Old 5th April 2009, 02:44 AM   #2
fb is offline fb  Australia
There's a linear phase eq vst in the free reaplugs package. You can draw in whatever curve you want.
Or there's sonalksis FreeG, which is just a fancy db slider, put it after your eq plugin.
There are several free effects chainer vst plugins to string it together if need be.
Should work with foobar's vst wrapper.
Old 5th April 2009, 09:44 PM   #3
Thanks, interesting looking stuff, winamp gets a little unstable with the vst chainer, so i looked around and found a "250 band EQ" winamp plugin, which lets me draw a curve and then shift left to right.
Seems to be doing what i want.
Now i can start learning about quality cross over parts, even if i keep it at 3500, i may look at the parts it uses and see how different parts affect the overall result.
Old 6th April 2009, 04:06 AM   #4
Thanks again, foobar locking up on vst may have fixed my vst issues, it locked up on a vst plugin, after removing the whole pack i was able to give the Rea stuff another try and i think ReaFir may do what i want, thanks
Determining Xover Point with Waveguide Horizons Multi-Way 14 19th November 2008 04:43 PM
Lowest Xover point for SEAS 27TDFC xmutan Multi-Way 15 29th December 2006 09:01 PM
Highest sub xover point for music regal Subwoofers 3 15th August 2005 02:09 AM
Dayton III and active Xover point mik Multi-Way 1 5th December 2004 11:14 AM
Acoustic xover point? woody Multi-Way 2 9th January 2002 06:08 AM
Page generated in 0.07870 seconds (75.18% PHP - 24.82% MySQL) with 10 queries
