Direct (or almost direct) replacement for Morel MW144? Direct (or almost direct) replacement for Morel MW144? - diyAudio
Old 4th April 2009, 10:42 AM   #1
mr_push_pull is offline mr_push_pull  Europe
Send a message via Yahoo to mr_push_pull
Default Direct (or almost direct) replacement for Morel MW144?
Hello everyone,
It's been a while since my last post here.
A few years back I built these 2-way ported enclosures using the Morel MW144 and MDT32 drivers (will post xover and enclosure details if needed). Yesterday, because of a malfunctioning amp, I burned one of the woofers. Since I'm not very happy with the sound, I was thinking about changing the drivers with something with close specs which will match the enclosure (both physically and spec-wise) and would require little modifications to the XO. Lower price also a big plus (at $100 the Morels are not on the cheap side for a poly 5'' mid-bass). Maybe Hi-Vi? Any other suggestions?
Old 19th April 2009, 04:43 PM   #2
Anyone?
Direct (or almost direct) replacement for Morel MW144?Hide this!Advertise here!
quad 303 pcb -- direct replacement / modification bigpanda Swap Meet 5 9th June 2016 09:49 PM
Anyone used this combination: Morel MW144 + MDT32S? mr_push_pull Multi-Way 3 12th January 2012 09:52 AM
Better Sounding Direct Replacement For OPA OP37 In Jolida JD9 Phono Stage XTRprof Analogue Source 5 30th June 2007 10:00 AM
Good Souinding Direct Replacement For 325 / OP 37 XTRprof Tubes / Valves 1 19th June 2007 12:09 PM
OnSemi MJL3281A/1302A direct replacement for SK 2SC3856/2SA1492 ? JohnSz Solid State 15 24th November 2005 10:29 PM
Copyright 1999-2017 diyAudio
