Side vs Downward firing sub driver
Old 24th April 2003, 07:26 PM   #11
BigDaddyD is offline BigDaddyD  United States
Yeah, I saw your other thread after I saw this one.
You know, when I was 17 (way too long ago) I took a cab my father already had, tried to duplicate it using scrap plywood in his worshop (3/4 inch at any rate, but with way too many voids) and then dropped a couple of Radio Shack 15" woofers, 8" midranges and horn tweeters into both boxes. Crossover was straight off the shelf as well. Damn I thought those things sounded good!
You're way ahead of me on the curve at that age. Of course, back then no one had too much other than RS. I'm not sure Speaker Builder magazine was even around at the time. Keep working at it (and drop a Shiva or Tempest in that box when you get a chance!)
Old 24th April 2003, 10:25 PM   #12
JoeBob is offline JoeBob  Canada
JoeBob's Avatar
When you were seventeen, I bet there was no internet for you to read all this stuff on, that's probably the reason why
Old 24th April 2003, 11:50 PM   #13
Nappylady is offline Nappylady  United States
Nappylady's Avatar
Send a message via ICQ to Nappylady Send a message via AIM to Nappylady Send a message via MSN to Nappylady Send a message via Yahoo to Nappylady
well, folks, I'm 19, living at home, and I'm just building my first pair, and I have to say, they're horrid!
The 15"ers on them have very limited excursion, so low bass above 2 watts causes the woofers to bottom out (Waah!) and make this horrible banging noise... the tweeters are not bad, peizo, and the 2.5-way config I've got them in is actually fairly nice to listen to... it's a sealed box so the bass is 3dB quieter than I'd like, but with a little EQ it's just fine.
I want to sell the boxes as fast as I can once I get the finish put on them, so I can build some better ones.... already plans are in the works for a 3-way completely amped speaker pair (VERY ambitious) so all you need is wall current and a line-level signal...
anyway... I feel pretty good for being 19.
Old 25th April 2003, 12:11 AM   #14
Sch3mat1c is offline Sch3mat1c  United States
Sch3mat1c's Avatar
Send a message via ICQ to Sch3mat1c Send a message via AIM to Sch3mat1c
Uh, I don't know why a woofer would be 2W so you might've mounted it wrong, bending the frame and making it scrape. Try loosening some screws and see if it gets better. I have a few speaks like this.
Tim
Seven Transistor Labs, LLC
Projects and Resources / Electronic Design and Consultation
Old 25th April 2003, 12:49 AM   #15
Nappylady's Avatar
Really? Hmm...
At 1 watt, it gives quite a bit of excursion (~1/2") at the low frequencies without any unpleasant noises... when turned up much higher, there is a new sound accompanying kick drums that sounds, by my intuition, like the voice coil hitting the back plate. Guessing by where I see things, I think this is a real possibility...
anyway, I didn't mean to hijack the thread like that... please resume normal discussion.
I'd heard that by making a sub down-firing, it eliminated an unpleasant artifact of PA speakers where, if you're just the wrong distance away, the bass is really weak... this being undesirable, down-firing woofers were developed in order to reduce or eliminate the effect.
Anyone know about this?
Old 25th April 2003, 12:51 AM   #16
JoeBob's Avatar
2W won't move a woofer that much, unless you've got almost no Xmax. I'd check it again, it's worth a try.
Old 25th April 2003, 03:17 AM   #17
Sch3mat1c's Avatar
Yeah. I just don't buy 1W for a whole half inch...sure you didn't mean half milimeter?
Thread hijack my butt.. (oops ) this thread's had no strictly-on-topic posts since Dave Bullet. Besides, this refers to bass speakers, that's what the thread was originally about so it's not too far off
Tim
Old 25th April 2003, 03:35 AM   #18
SkinnyBoy is offline SkinnyBoy  Australia
Banned
Send a message via MSN to SkinnyBoy
Nah, I want to get a 12inch XLS Peerless and a Passive radiator or 2.. Don't wanna waste my money on cheapish or hard to find parts.. lol and I can get the Peerlesses at trade price.. so, thats $200 AU instead of $300 lol, why not? Hey, now I might be thread-jacking.. lol
Side vs Downward firing sub driverHide this!Advertise here!
Down firing vs side firing? Tee-Bruce Subwoofers 36 26th August 2009 07:32 AM
Pros & cons of downward firing subs smithy666 Subwoofers 0 30th January 2007 05:57 AM
Woofer: side firing pair vs front firing? tcpip Multi-Way 13 9th September 2005 03:13 PM
side firing sub chainenoble Subwoofers 2 29th August 2005 04:29 AM
Downward firing Sub mart34 Subwoofers 10 11th February 2005 05:22 PM
