Wich is best : ribbon or dome tweeters ?
Old 2nd April 2009, 06:18 PM   #1
lduarte1973 is offline lduarte1973  Portugal
Banned
Default Wich is best : ribbon or dome tweeters ?
Old 2nd April 2009, 07:01 PM   #2
Lindell is offline Lindell  Sweden
A coax dome ribbon would rule ?
Old 2nd April 2009, 07:16 PM   #3
roger_lew is offline roger_lew  United States
roger_lew's Avatar
Hey Luis,
"Best" is sort of a trick question when it comes to speakers. It really boils down to your design objectives and constraints.
Domes generally have better polar response in the vertical plane, lower distortion at higher volumes, and can generally be crossed over lower than ribbons with more gradual slopes.
True ribbon tweeters generally have higher efficiency, flatter impedance, and better impulse response.
You might take a look at Lynn Olsen's "The Art of Speaker Design." I think you'll find it interesting and it provides some historical perspective in regard to your questions. I go through it about once a year.
http://www.nutshellhifi.com/library/...r-design1.html
Roger
Old 2nd April 2009, 08:49 PM   #4
dukeoyork is offline dukeoyork  Abu Dhabi
one of each?
Old 2nd April 2009, 09:04 PM   #5
Cal Weldon is offline Cal Weldon  Canada
Speakerholic
Cal Weldon's Avatar
No.
Roger's advise is good.
planet10 needs your help:
Let's help Ruth and Dave
Old 2nd April 2009, 09:23 PM   #6
i had the pleasure of having some apogee duetta II's for a while. i expected the dispersion to be really wide, because the ribbon is flat. i was very surprised at how directional the tweeters were. you had to be pretty much right in line with them, an it became obvious that these speakers need a pretty big room to do them justice, 'cause the sweet spot was really a spot, lol. i don't know that a good dome tweeter on top wouldn't have solved this.
i didn't find the larger panel suffered from the same problem.
Old 2nd April 2009, 09:39 PM   #7
BlueWizard is offline BlueWizard  United States
Let's not forget there is a 'for the money' element here.
Is the real question, is a Dome better than a Ribbon for equal money?
Or, is it for any amount of money?
If any amount, likely a ribbon wins, but if you factor in a budget, then a dome wins.
Also, you can find domes for $10 to $20, but I don't think you can find ribbons that cheap. So, in that price range Dome wins because there are no ribbons.
Then of course, it depends on which ribbon and which dome. At a given price point, one many be better than the other independent of it being a dome or ribbon. It may hinge on other design factors.
I think budget, application, and desired design result play more of a factor than any blanket statement of one being better than the other. Likely both have plus and minus, and it is up to you as the design to determine if you can accentuate the pluses and minimize the minuses to your advantage.
Steve/bluewizard
Old 2nd April 2009, 10:14 PM   #8
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
If someone would set their mind to designing a high quality CONE tweeter, it might be the winner
Unfortunately they are all cheap
sometimes we know very little, and sometimes we know too much
Old 2nd April 2009, 10:32 PM   #9
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
Originally posted by dukeoyork
one of each?
Like Dali?
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 2nd April 2009, 10:34 PM   #10
frugal-phile(tm)
planet10's Avatar
What about cone tweeters? Horns?
Each has its place depending on the context.
Personally i'm not a big fan of domes (some concave domes are OK -- really sort of a cone tweeter)
dave
Wich is best : ribbon or dome tweeters ?Hide this!Advertise here!
FS: Dome tweeters johnmik Swap Meet 0 18th June 2006 04:57 AM
ATC mid dome and ribbon tweeter Vil Multi-Way 69 16th September 2005 10:08 AM
Tweeter Box Crossover with Ribbon and Bullet Dome Tweeters doccbst Planars & Exotics 2 5th August 2005 05:54 PM
ribbon vs dome tweeters MyNameIsJake Multi-Way 15 21st April 2005 10:17 AM
Using a Visaton Ribbon with a Morel MDM55 dome mid Chagall Multi-Way 4 18th June 2004 07:13 AM
