#21 |
Lol... I'm going to look for a project for that in my amateur radio magazines. I've seen them before and they are easy to build, they just have to be calibrated.
-- Duo, W1ngs, VA7MON, and lesser known handles. -- -- http://www.w1ngselectronics.com -- My Work and Projects -- |
#22 |
the worlds loudest cars at DB comps now are in the mid 180s, and the highest i believe is 187.... most are using 10's of thousands of watts (running from 18vdc as per the rules) and tons of subs.
-chris |
#23 |
I once checked a couple of the RS SPL meters against some very expensive Bruel and Kjaer (drool) big iron. It was a simple test using the B-K microphone capsule-calibrating unit. Surprises of surprises, the RS meters mic is the same diameter as the Bruel...
Not only were the cheap little RS things reasonably consistent among them selves, they also tracked the lab grade stuff within a dB or two. I had this CD produced by B-K demonstrating their studio microphones that had a bunch of test signals recorded at the end. The octave and 1/3 octave noise recordings worked great with that cheap little meter for setting up EQ. I lent them to someone a while back and haven’t seen them since... Of course for next to nothing it was a nice setup, but honestly, its the Bruel Kjaer stuff that I really miss. Mr. Joe Dirt (R) has a nice looking SPL meter for sale in the trading post: professional sound level meter I think that if a person were to set out and try and build a descent SPL meter from scratch that there would be two big challenges. The first would be finding a reference source to calibrate against. The second would be getting defining and calibrating the response curves for A, B, and C weighting. These weights correspond to human hearing response (Fletcher-Munson equal loudness curves), inverse hearing response, and something else that I cant think of at the moment. This link explains it better than I can: http://www.me.psu.edu/lamancusa/me458/4_metrics.pdf If you find a good article that covers this stuff, it would be an interesting reed. |
#24 |
here is an intersting scale,
note that the pressure produced after an atomic bomb ranges from 10-15psi... these super db cars are nearing that... and since it in a log scale, you can see a system of 200db (30psi) would destroy nearly anything near it. my car measures in at a bit over 130db, and i can really really feel it (makes your hair jump), its amazing this it is only .01psi. SPL = 20 Log(p/p ref) p = pressure in pascals p ref = reference pressure in pascals = 2 x 10^-5 Pa (pascals) to convert psi to pascals you need this: Pa/psi (approximately) so take your relative PSI value convert it to pascals and dump it back into the above formula. 2 psi = 13638 Pa SPL = 20 Log [13638/(2x10^-5)] = 176.7 dB acoustical More dB SPL versus PSI dB acoustical - PSI 50.7 - 0.000001 56.7 - 0.000002 60.2 - 0.000003 62.7 - 0.000004 64.6 - 0.000005 66.2 - 0.000006 67.6 - 0.000007 68.7 - 0.000008 69.7 - 0.000009 70.7 - 0.00001 76.7 - 0.00002 80.2 - 0.00003 82.7 - 0.00004 84.6 - 0.00005 86.2 - 0.00006 87.6 - 0.00007 88.7 - 0.00008 89.7 - 0.00009 90.7 - 0.0001 96.7 - 0.0002 100.2 - 0.0003 102.7 - 0.0004 104.6 - 0.0005 106.2 - 0.0006 107.6 - 0.0007 108.7 - 0.0008 109.7 - 0.0009 110.7 - 0.001 116.7 - 0.002 120.2 - 0.003 122.7 - 0.004 124.6 - 0.005 126.2 - 0.006 127.6 - 0.007 128.7 - 0.008 129.7 - 0.009 130.7 - 0.01 136.7 - 0.02 140.2 - 0.03 142.7 - 0.04 144.6 - 0.05 146.2 - 0.06 147.6 - 0.07 148.7 - 0.08 149.7 - 0.09 150.7 - 0.1 156.7 - 0.2 160.2 - 0.3 162.7 - 0.4 164.6 - 0.5 166.2 - 0.6 167.6 - 0.7 168.7 - 0.8 169.7 - 0.9 170.7 - 1.0 171.5 - 1.1 172.2 - 1.2 172.9 - 1.3 173.6 - 1.4 174.2 - 1.5 174.7 - 1.6 175.3 - 1.7 175.8 - 1.8 176.2 - 1.9 176.7 - 2.0 180.2 - 3.0 182.7 - 4.0 184.6 - 5.0 186.2 - 6.0 187.6 - 7.0 188.7 - 8.0 189.7 - 9.0 190.7 - 10.0 191.5 - 11.0 192.2 - 12.0 192.9 - 13.0 193.6 - 14.0 194.2 - 15.0 194.7 - 16.0 195.3 - 17.0 195.8 - 18.0 196.2 - 19.0 196.7 - 20.0 197.1 - 21.0 197.5 - 22.0 197.9 - 23.0 198.3 - 24.0 198.6 - 25.0 199.0 - 26.0 199.3 - 27.0 199.6 - 28.0 199.9 - 29.0 200.2 - 30.0 -chris |
#25 |
It's really amazing how little an eardrum can detect.
#26 |
Ive heard the analogy that if our vision were as sensitive as our hearing that we would be able to see a candle burning in on the beach in California while standing on the beach in North Carolina. (Of course ignoring that part about the curvature of the planet)
#27 |
That makes sense. Just think about all the different nuances of thing you can detect with hearing. So many things can be observed with sound.
#28 | |
Checkout making your own electret mic at Speakerbuilder.net . Parts are only a few dollars.Ok - it won't be callibrated, but even if a few dB off you should be able to get some rough idea. Oh yeah - you'll need some software like Speaker Workshop (free from Audua) to measure the response. Hope that helps, David. |
#29 |
For some years, I worked with 1Joule pulsed lasers, and we used to joke about that you could look at it,- twice...
For the 200dBs,-.. " I will say thiz only onze...." ( I think the euros get the pun...) |
#30 | |
| Measure the output of a bridged class D | ocool_15 | Class D | 5 | 20th April 2008 07:12 PM |
| How to measure amp power output | hernanstafe | Parts | 2 | 16th February 2007 01:27 AM |
| How to measure the output impedance of the DAC chip | ergo | Solid State | 2 | 9th June 2004 07:07 AM |
| How do I calculate (or measure) my amp's output impedance? | Saurav | Tubes / Valves | 22 | 27th September 2003 03:55 AM |
| How to measure digital output of CD. | protos | Digital Source | 0 | 5th March 2003 11:50 AM |
