Old 27th March 2009, 11:33 AM   #1
marcels is offline marcels  Netherlands
Question Peerless tweeters (what model!)
I am looking for an old model peerless tweeters but cant seem to find information about them. Maybe someone on the forum can tell me what model they are, and maybe where i van find them.
I know they are out of production so i am also considering an alternative, closest i could find was the peerless DT-105H but since i dont know the characteristics i cant be sure.
Thanx !
Old 27th March 2009, 01:45 PM   #2
I know those Peerless KO10DT tweeters intimately, the top end is
not good at all and a modern tweeter will likely work much better.
The size is very similar to the ubiquitous 12cm x 9cm Audax.
/sreten.
Old 27th March 2009, 02:49 PM   #3
Tnx for the info,
I didnt know the tweeter didn't perform well at the top range, shape at the moment isn't really a problem since i am building the speaker myself.
I do have a Kef t27 so that might be an option, is there another tweeter u would recommend in stead of the Peerless ?
Old 27th March 2009, 04:18 PM   #4
What speakers are you building ? The T27 may or may not suit.
FWIW the soft domes of that period were in breakup mode in
the top octave, with a treble rise being very common, especially
in tweeters left over from a selection process for manafacturers.
/sreten.
Old 27th March 2009, 04:44 PM   #5
sreten,
I am building a speaker (3way) based on :
* Kef b200 SP1039 (housing as TL based on this speaker)
* Peerless M122
* tweeter (original design was with the peerless tweeter)
I am using a Visaton filter VS-HW3/120NG 8
Old 27th March 2009, 06:04 PM   #6
http://www.rjbaudio.com/Audiofiles/FRDtools.html
http://www.geocities.com/woove99/Spk...esigningXO.htm
http://www.zaphaudio.com/
http://www.rjbaudio.com/projects.html
http://www.geocities.com/woove99/Spkrbldg/
http://www.troelsgravesen.dk/Diy_Lou...r_Projects.htm
http://htguide.com/forum/forumdisplay.php4?f=39
http://www.humblehomemadehifi.com/
That visaton crossover looks dreadful.
http://www.d-s-t.com.au/data/Peerless/821615.pdf
Decent enough midrange but needs crossing over high.
Will need to be severely slugged volume wise to match a B200.
The T27 should work absolutely fine with it.
http://www.hifiloudspeakers.info/Ana...riveUnits.html
Not all B200's are the same, the SP1039 has a monster magnet.
Should be fine if you model and build your crossover correctly.
/sreten.
Old 27th March 2009, 08:22 PM   #7
Thanx,
Thats a lot of info
I'm a noob on crossovers and speaker design overall, ill start with what i have atm (includes the Vistaton filter) and start looking into building a crossover that matches the unites better.
Old 28th March 2009, 02:15 PM   #8
http://undefinition.googlepages.com/diy
Hi, also worth reading, /sreten.
WTB- Peerless XLS 8" drivers, model 830491 toolfan91 Swap Meet 0 19th March 2009 02:46 PM
Peerless HDS Tweeters For Sale mp006ltk Swap Meet 0 3rd August 2008 09:12 PM
WTB/WTT for Peerless HDS Tweeters (810921) azngotskills Swap Meet 0 2nd August 2008 03:44 AM
KLH Model Six Tweeters JMB Multi-Way 1 31st October 2006 11:02 PM
Peerless MODEL L-602 speakers Tomv Multi-Way 0 1st August 2005 07:03 PM
Page generated in 0.09520 seconds (77.92% PHP - 22.08% MySQL) with 11 queries
