Hi, Ive been given a pair of speakers and was wondering if anyone had any idea what they are.
The only info on them is a pair of serial numbers:- 1066 Left & 1067 right. I've pulled a midrange out, it has the serial number 796607 or maybe 79g607. The surround has completely withered but if I push the centre it moves in and very smoothly. So I reckon it can be easily mended if it's worthwhile. So anybody got a clue what they are? |
#2 |
another picture
#3 |
another picture
Haven't yet got the speakers into my basement, so will maybe find more info when I open them up. |
#4 |
Well, you have a KEF B139 woofer, and the small cones look like Peerless. Is the enclosure on the smaller cone driver attached or a separate piece?
The freaks stick together, they are a tight old crew |
#5 |
thanks for the reply.
It's attached, see picture. |
#6 |
Yes, Peerless. A number of speakers used that one. Dalquest DQ 10 is an example. Sequerra 1 is another.
#7 |
wow, it looks they these drivers have graced some pretty impressive speakers over the years. I'm picking them up in a bit so I'll be able to investigate further.
#8 |
The Sequerra packed the exterior of the plastic enclosure with calk or putty to dampen it. They also removed the dust cap and put a phase plug in it's place.
#9 |
frugal-phile(tm)
Kef B139, still a usable bass driver.... often used in a TL.
http://t-linespeakers.org/drivers/b139.html Scott & i revisted the B139 TL using modern modeling tools. (2 possible configs shown at the link, but it could be done other ways). http://t-linespeakers.org/projects/vProjects.html Modrange is the closed back Peerless K040, used in quite a few speakers including some of the less expensive IMFs and the 2nd iteration of the Rogers Pro9TL The tweeter -- can you post a closeup of the front and the back? The XO is classic British. Someone common must have been making XOs for a lot of manufacturers. The B139 is worth reusing... the tweeters in some "i need a tweeter, ant tweeter" application, and the XO for parts (mostly the chokes -- modern caps are much better) dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#10 |
will do when i pick them up later
| Mystery circuit | Nickeroo | Solid State | 13 | 26th September 2008 10:30 PM |
| Mystery RF amp | spooney | Car Audio | 11 | 25th April 2008 06:14 PM |
| little 6.5 mystery ... | oface | Full Range | 6 | 4th November 2007 11:20 PM |
| Mystery SE OPT | alexmoose | Tubes / Valves | 4 | 11th July 2006 01:29 AM |
| mystery... | mista2 | Multi-Way | 1 | 14th January 2005 04:20 AM |
| Page generated in 0.09699 seconds (76.77% PHP - 23.23% MySQL) with 11 queries |
