Mystery loudspeakers
Old 27th March 2009, 11:33 AM   #11
marcels is offline marcels  Netherlands
Originally posted by delsix
thanks for the reply.
It's attached, see picture.
I am pretty sure these are the Peerless M122
Old 27th March 2009, 01:27 PM   #12
R.I.P.
They are British made Nightingale loudspeakers I recall.
KEF B139, Peerless KO40MRF sealed midrange (there was a
UK coated version of this, done by Falcon Acoustics), and
what looks like an Isophon KK8 tweeter, the crossover is
by Falcon Acoustics, they made a lot of British crossovers.
If you restore them as is, the elcaps might be worth replacing,
though the ones used are far better quality than the typical
far eastern variety available at the time.
As I recall they had a deep reticulated foam front grille and
and five sided reticulated foam hood, fitting over the whole
top section, both of these simply disintegrate over time.
/sreten.
Old 27th March 2009, 05:09 PM   #13
delsix is offline delsix  United Kingdom
I think you may well be right, the crossovers are Falcon Acoustics model PCB3A.
I've had one of the kef b139 units out and found that the main cabinet is a transmission line . So I'm now thinking that a pair of transmission line subs would be a good start.
A couple of questions,
is it possible to mend the peerless midrange drivers? Apart from the surrounds, which have completely withered, they appear in pretty good condition.
Also, can someone recommend suitable (I mean cheap here) replacement tweeters
Old 27th March 2009, 05:16 PM   #14
close up of tweeter
Old 27th March 2009, 05:26 PM   #15
and the back
Old 27th March 2009, 05:33 PM   #16
R.I.P.
You can certainly refoam the mid ranges with a kit from e-pray.
Might not be perfect but should make them usable / serviceable.
If your tweeters are fried Maplin sell a 5 a pop dome tweeter.
Not perfect by any means but will make them usable / serviceable.
You may have to adjust the treble resistors in the crossover.
/sreten.
Old 27th March 2009, 06:39 PM   #17
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
Tou could try to restore them. You might be better to look at them as a pair of nice woofers ready for you to add a modern 1-way or 2-way minimonitor on top. (suggest active XO between bass & sats)
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 27th March 2009, 07:55 PM   #18
Now funny you should say that as I have a pair of fostex fe87 3" drivers currently sat in a couple of old planks desperately in need of bass. I've also got a set of active filter boards from the GB which have just gathered dust.
I have zero experience with crossovers. However, I'll have a stab at 175Hz crossover point and 3rd (I'm really guessing now) order filter.
Open baffle or box, no idea really tho neither would be difficult
Hopefully that would make a nice set of speakers for the basement, give me a pair of active subs if I needed them and leave open a future project to build a really nice pair of mini monitors, oh and be really cheap to boot.
Am I in the right ballpark?
Old 27th March 2009, 07:57 PM   #19
chris661 is offline chris661  United Kingdom
chris661's Avatar
If you want quick results, I'd agree with Dave when he said about a couple of small monitor speakers, and keep the Kef bass driver.
However, I would be curious about how the other drivers sound, so, if I were you, I'd try to restore them, see what they sound like.
If you don't like the sound, get some small monitors, if you do like the sound, keep them and enjoy.
My work: www.grimshawaudio.com
Old 27th March 2009, 11:39 PM   #20
frugal-phile(tm)
planet10's Avatar
Don't dismiss the FE87 as potential minimonitors. Tricked up i understand they can be very surprising (the FF85 sure is). With the B139 you want to keep the XO below 250 Hz, they have a particularily nasty circa 1 k resonance. The "box" for the FE87 could be as simple as an open baffle the width of the box (and then the XO point is chosen to relate to that -- ie around the bafflestep point). 3rd order would be fine. On our FF85 to bass driver i'm using 2nd order HP, 1st order kowpass, butit is a special case.
dave
Mystery loudspeakersHide this!Advertise here!
Mystery circuit Nickeroo Solid State 13 26th September 2008 10:30 PM
Mystery RF amp spooney Car Audio 11 25th April 2008 06:14 PM
little 6.5 mystery ... oface Full Range 6 4th November 2007 11:20 PM
Mystery SE OPT alexmoose Tubes / Valves 4 11th July 2006 01:29 AM
mystery... mista2 Multi-Way 1 14th January 2005 04:20 AM
