Noob needs help building enclosure / x-over
Old 26th March 2009, 06:34 PM   #1
Ettienne is offline Ettienne  Portugal
Default Noob needs help building enclosure / x-over
Hi!
A friend of mine gave me a pair of beyma tweeters T2030 and a pair of 5MP60N for helping him rebuilding his car engine. The problem is that the only combination that i found when i googled about this speakers is an active crossover wich i'm unable to understand and build. So, i'm asking for help / directions on hou to build a crossover for my setup wich will be fed by chipamp's lm1875. I would also need tips on an enclosure for the speakers...
PS:
I'm not a guy with a background on electronics but i'm a quick learner, as long as it's a simultaneously explaining and building process.
PS2:
Sorry for my english, but it's not my native language.
(1st post)
Old 26th March 2009, 07:00 PM   #2
ultrachrome is offline ultrachrome  United States
Basics of bi-amping: http://sound.westhost.com/bi-amp.htm
2/3-way LR active XO: http://sound.westhost.com/project09.htm
Old 26th March 2009, 07:33 PM   #3
Drew Eckhardt is offline Drew Eckhardt  United States
Linkwitz active filter cook book:
http://www.linkwitzlab.com/filters.htm
Linkwitz circuit boards. Op-amp power supplies are properly biased, RF low-pass circuits are included in feedback loops where possible, the layout is good.
http://www.linkwitzlab.com/pcb.htm
Linkwitz Pluto electronics. 2-way LR4 cross-over, notch filters on both outputs, all-pass for time alignment, Linkwitz Transform on the woofer, shelving low-pass on the woofer for baffle step or dipole compensation, LM3886 for the tweeter channel, bridged LM3886 for the woofer, power supplies.
http://www.linkwitzlab.com/Pluto/electronics.htm
Old 27th March 2009, 03:35 PM   #4
R.I.P.
http://www.rjbaudio.com/Audiofiles/FRDtools.html
http://www.geocities.com/woove99/Spk...esigningXO.htm
http://www.zaphaudio.com/
http://www.rjbaudio.com/projects.html
http://www.geocities.com/woove99/Spkrbldg/
The above pretty much covers crossover and box design.
You might want to add a bass unit (or two) if you do not want
to build a minuture. With the two drivers bass will be restricted.
/sreten.
Noob needs help building enclosure / x-overHide this!Advertise here!
Noob building first amp: please check my connections maurycy Chip Amps 8 19th August 2007 06:52 PM
NOOB! Thinking of building a 4 ch 3875 amp - questions.. quickshift Chip Amps 7 7th August 2005 02:57 PM
