Hey Guys
I have a pair of Yorkville Unity Horns, currently on the floor in my listening space. http://www.yorkville.com/products.as...&cat=38&id=254 I'd like to either diy or buy some stands for them to get them up to the best height, assuming I'm seated at my couch (puts my ears at ~40"). I had read that you want ear level at the point between the woofer and the horn. For the Yorkvilles this would make the height of the stands ~23-24" as the midpoint between the woofer and the horn section is 16.5" from the ground. Does this logic sound reasonable? Thanks in advance, guys! Jim |
#2 |
Personally, I listen with my ears level with the midpoint of the horn (i.e. right on the tweeter axis). IMHO this seems most natural, as it puts you in the most even response location. If you are much below or above, the power response will be brighter than the direct sound. I guess this may be a good thing depending on your environment, though.
#3 |
frugal-phile(tm)
With the Unity, you don't have a tweeter, you have a "compound mid-tweeter". IIRC XO is at ~300 Hz. Given that you want to be looking right into the middle of the horn.
Have you removed the grills? dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#4 |
I appreciate the input guys. My thinking with the halfway between the horn section and the woofer was based on a comment made by Earl Geddes regarding his speakers, which, I see some similarity with the Unitys.
Dave, the first thing I did was remove the grills! Jim |
| Yorkville 400B Bass Head Repair Help | cm961 | Solid State | 0 | 20th February 2009 02:47 PM |
| BIB and ceiling height | Mr.Mekulic | Full Range | 7 | 21st November 2007 07:58 PM |
| What frequency do that ones run at Yorkville NX55P? | lindomar | Class D | 0 | 3rd November 2007 12:33 PM |
| Yorkville PA powered head distortion | still4given | Solid State | 4 | 14th February 2005 03:31 AM |
| Page generated in 0.06054 seconds (80.98% PHP - 19.02% MySQL) with 10 queries |
