Gonna downsize from my JBL 2226H to something smaller, considering my room size.
They dont need to go very deep, 50hz or so will do.. BUT they have to be quick enough to keep up with my horns. Pros and cons of each driver? |
#2 |
This comparison has come up a few times lately. I'll give you a couple links to my responses regarding the comparison.
Originally the comparison came up in the following thread. You can read my response and the rest of the thread if you want. http://www.avsforum.com/avs-vb/showp...&postcount=221 We got a little more into some of the specifics on page 2 of this thread here: http://www.avsforum.com/avs-vb/showt...t=2226h&page=2 In general the TD12M will have better power handling/power compression due to the way the copper sleeve pulls heat from the coil. It will have cleaner high frequency extension as there is no dustcap breakup and a much better damped cone breakup. High frequency extension is also much higher due to the lower inductance. The lower and more linear inductance also means, much lower distortion due very little change in Le with excursion and greatly lowered flux modulation. All in all there isn't much of a comparison. John |
#4 |
Custom Title
Possibly due to excursion related fluid displacement
Or that most woofer failures are from overexcursion, not heat.
I write for www.enjoythemusic.com in the DIY section. You may find yourself getting a preview of a project in-progress. Be warned! |
#5 | |
frugal-phile(tm)
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#6 | |
#7 | |
Building a 2.1 system out of a 3/4"x4'x8' sheet |
#8 |
Custom Title
Make sure you use a polycone if you're going to test excursion vs. ferrofluid displacement. Would be a shame to soak magnetic fluid into the paper cone
#9 | |
frugal-phile(tm)
dave
#10 | |
Custom Title
Hey, did you measure motor strength related to this? I'd think it'd act as a brake to motion in one direction and an enhancement in the opposite (Presumably it would 'pull' towards the polepiece), probably increasing even order distortion quite a bit. Any observable effects related to this you noted?
| Beyma tpl-150 + Lambda TD12M's | studiotech | Multi-Way | 21 | 24th July 2009 12:51 PM |
| AE TD12M cheap alternative - Faital 12PR300? | Defo | Multi-Way | 60 | 13th June 2009 12:21 AM |
| Ping GM/Pkitt: MLTL for Lambda TD12M? | JoshK | Multi-Way | 11 | 2nd June 2009 02:00 PM |
| two (2) 2206h LF drivers 330 for both | part2wanksta | Swap Meet | 0 | 22nd February 2008 12:27 AM |
| what to do with (2) 2206h LF drivers | part2wanksta | Multi-Way | 7 | 14th February 2008 05:50 PM |
| Page generated in 0.11434 seconds (80.19% PHP - 19.81% MySQL) with 10 queries |
