#31 |
Thanks for the reminder Dave.
The final crossover I'm using is as follows. For the tweeter I went second order at 7200Hz. I used a 2.41 uF cap and a 0.20 mH inductor in the arrangement shown in the first schematic. (The attenuation resistors are also in there) For the Mids low pass I used a second order low pass with a 0.27 mH inductor and a 1.84 uF cap. The high pass for the mid is a first order with a cap of 68 uF. For the woofer I used a first order low pass with a 3.76 mH inductor. So far I really like the way it sounds. The project I'm working on now it to bi amp them so that I can put more power to the SDX7 as they do sound a little strong on the high end. Let me know if you have any other questions and I'll try to answer them a little faster. |
#32 |
frugal-phile(tm)
Thanx Sam. Did you ever mod the SDX7s?
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#33 |
frugal-phile(tm)
Sam,
Can you vet this XO map. I guessed at the driver polarities, You also didn't mention a zobel on the SDX7 that was on the XO early in the thread. dave
#34 |
Dave,
I never did do the cone treatment. I might have a try at it in the future but right now I'm working on another project that's taking up my time. The XO you posted seems to be correct. I never put a zobel on the SDX7. If there is any other information you were wondering about let me know. Sam |
#35 |
frugal-phile(tm)
Do report back when you've done the SDX7.
I just wanted to make sure i had the XO right. dave
#36 |
I did a similar setup tonight with a discontinued Tangband tweeter (part number not known at this point). Only first order on the midrange Low Pass though. Why did you go 2nd Order Sam? My setup sounds nice. Just two boxes piled up with tweeter sitting on top so far. 10 litre sealed for SDX7, 5.5 litre aperiodic for FR125. I tried ported on SDX7 but the bass was flabby. A better less sibilant tweeter is now something I need. Ideas?
BTW, the pictures of SAMXT's boxes on this thread do not show up anymore.... Last edited by GringoAudio; 31st October 2011 at 06:28 AM. Reason: forgot a word |
#37 |
My tweeter was crossed in at 4KHz first order ...so same drivers...slightly different x-over....values all approx. the same. 4mH coil on SDX7. 53uF and .28mH on FR125. I will have to try a 2nd order x-over some day. Sweet spot is bigger right?
#38 |
I padded down the FR125 on my version of this. Too shouty. Different tweeter. AND YES this SDX7 driver needs a sealed box!!
| Bookshelf speakers | unknownuser200 | Multi-Way | 20 | 21st January 2012 06:09 PM |
| ADC 404 Bookshelf Speakers | Ed Holland | Multi-Way | 0 | 10th December 2008 08:06 PM |
| Bookshelf Speakers | Sammich | Multi-Way | 5 | 29th June 2007 08:01 AM |
| bookshelf speakers - need help | ziv_r | Multi-Way | 1 | 24th April 2006 11:20 AM |
| Bookshelf Speakers | avguy | Multi-Way | 32 | 10th November 2003 10:36 AM |
| Page generated in 0.08544 seconds (76.78% PHP - 23.22% MySQL) with 11 queries |
