Old 21st March 2009, 10:47 AM   #1
jamikl is offline jamikl  Australia
Default would this be anywhere accurate
I have tried to simulate a ripole in horn response. I have the two chambers one at the front and one at the back. I could not figure out how to do it as a double ripole with the slot in the centre so have done it with the volumes of two single, one above the other.
The rear port is modeled as port in horn response and the dimensions are as it would be if they were side by side, ie. one on each side of the box at the rear. The slot is modeled as horn to simulate roughly round over of the slot edges. It is again modeled to the dimensions it would be if they were side by side. The parameters for the speaker used are attached.
If it worked something like this in room with room lift ( if any for a ripole ) it looks quite good I think.
Any comment or assistance welcome. I don't know how to attach the rest of the horn response windows but anyone who has the program can work it out quickly from here.
jamikl
Old 21st March 2009, 11:12 AM   #2
Just realised I made a big mistake and forgot path difference. Doesn't look any good at all now!!!!! Been working too hard!!!!
jamikl
Accurate <100 ppm HV49 crystal?? fmak Digital Source 26 13th February 2006 01:20 PM
Fast vs Accurate MaVo Multi-Way 3 25th January 2006 11:54 AM
Is WinISD always accurate? carlosfm Full Range 11 13th June 2005 03:02 PM
Accurate DIY Loudspeakers atticus Multi-Way 10 21st September 2004 06:10 PM
volume POT...NOT ACCURATE! moonshow Chip Amps 4 22nd March 2004 08:58 PM
Page generated in 0.07114 seconds (69.65% PHP - 30.35% MySQL) with 11 queries
