Old 19th March 2009, 08:31 PM   #1
rsk1 is offline rsk1  United States
Default Speakers for surround sound?
I have Altec-Lansing Santana IIs and M&K Satellite/subwoofer connected to my stereo system (different rooms). I am thinking of changing to surround sound. Can I still use these speakers? How do I match a center channel speaker to the Santanas as left and right channels? Or should I just buy a prepackaged systems, sell the speakers I have, and if so what are some recommendations? Thanks.
Old 19th March 2009, 08:36 PM   #2
Speakerholic
Cal Weldon's Avatar
You can use any speakers you like but it is best to have them all the same. Having said that, you will be happier with trying to fit a center channel in than to replace all with something less like the HT in a box type. Just make sure you match the sensitivities. A lot of sound comes from the center channel. You will also want to consider a powered woofer to augment the low end.
Next stop: Margaritaville
Some of Cal's stuff | Cal Weldon Consulting
Old 19th March 2009, 11:47 PM   #3
Key is offline Key  United States
A few recommendations.
If it is a music only setup - no TV, Screen, or Monitor in the center - it is recommended to use a matched center speaker. It is generally recommended for professionals to use the same speakers no matter how many channels - 2, 4, 5(.1), 7(.1) etc.. And if you want to hear the music as close to the way they hear it in the studio I recommend the same for a home.
There are a lot of prepackaged systems that are just garbage. They use a crossover around 120Hz and let a mono sub handle 20Hz - 120Hz. This setup is mainly for watching movies. There are some decent packages though that sound awesome so I can't just say that all package systems are bad.
But in general I think that the best sounding systems the "satellites" have a frequency response that is somewhat flat from 40Hz - 20Hz and then uses a sub to fill in the bass below that. There are some monitors that the frequency response has a natural slope from 40Hz - 20Hz that sound great without the use of a crossover. You just use a crossover on the sub and let the monitors stay full range.
Need help with surround sound tommytucker Everything Else 0 6th May 2009 07:33 PM
surround sound. kanifee Chip Amps 10 12th September 2008 09:54 AM
Surround sound from PC possible? cotdt Digital Source 7 29th December 2006 11:26 AM
surround sound MikeW Pass Labs 1 16th February 2006 08:30 PM
Creating a remote volume control for Creative 4.1 Digital Surround Sound Speakers mrcheese321 Parts 3 13th August 2004 07:40 AM
Page generated in 0.07836 seconds (72.51% PHP - 27.49% MySQL) with 10 queries
