I am working on putting together a set of fronts, this is what i got in mind.
A MTM design with 2 6.5 Woofers by SEAS Prestige line and a dome tweeter also by SEAS Prestige line. I choose SEAS because my dad has there Excel line and really like them a lot. I might be able to get a couple SEAS millenium tweeters off him for cheap for this build. Also I want to do a Active digital crossover for them, I have been recommended a Behringer DCX2496. A couple questions I have -Digital crossover vs Passive crossover, advantages and disadvantages -What 6.5 Woofer and Tweeter made by SEAS Prestige line would mesh together well and sound good in a MTM. |
#2 |
Take a look at the following links:
Mike's Proposed MTM Mike's MTM - Good Progress http://www.geocities.com/woove99/Spk...X_MTM_2Way.htm |
#3 | |
-flexibility, great for prototyping different filters -possible to use filters not available in passive/analog world (steep slope, arbitrary phase response) Cons: -may be expensive up front -may need to do AD conversion -multichannel volume control may be expensive Whichever way you go, more important are a good set measurements (incl. several from off-axis angles) from your drivers in your box and tailoring the crossover based on them. |
#4 |
Thanks for the links guys, really helped out a lot.
#5 |
If you're intereted in digital cross-overs you ought to check these guys out: http://groundsound.com/index.html
They also make amplifier kits! However being Danish they're kind of pricey, however I do believe they make excellent products. JohnZ |
| Vifa PL22WR09 vs SEAS Prestige P21RF/P for Recession Buster 3 way | rhapsodee | Multi-Way | 0 | 14th May 2009 03:02 PM |
| FS: 1 Seas H392 (25TNF prestige tweeter) | patchwork | Swap Meet | 0 | 12th November 2008 06:50 PM |
| SB Acoustics vs Seas Prestige | Audiodidakt | Multi-Way | 1 | 1st April 2008 03:14 PM |
| Differences between SEAS drivers (thinking of using p18's) | seagrasser | Multi-Way | 2 | 10th August 2007 06:12 AM |
| Cant decide between two drivers, in dire need of help | ccdoggy | Subwoofers | 2 | 12th February 2007 05:45 PM |
| Page generated in 0.08574 seconds (74.10% PHP - 25.90% MySQL) with 10 queries |
