Help needed: How do I fix a "pushed in" dust cap?
Old 17th March 2009, 04:35 PM   #1
pk is offline pk  Denmark
Default Help needed: How do I fix a "pushed in" dust cap?
Hello,
I just received an 8" cone driver that I bought on Ebay. Unfortunately the driver was not packed sufficiently, so the "dust cap" (the center part of the cone) has been "pushed in".
The drivers is a Ciare 8.50 NDMR with a paper cone
Can this be fixed, and how do I do it?
Any help will be much appreciated!
Best regards
Peter
Old 17th March 2009, 04:37 PM   #2
Pano is online now Pano  United States
Pano's Avatar
I've done it with a vacuum cleaner. Go gently!
Old 17th March 2009, 04:52 PM   #3
HK26147 is offline HK26147  United States
See also:
http://www.diyaudio.com/forums/showt...hreadid=139592
Old 17th March 2009, 05:21 PM   #4
widman is offline widman  United States
I've poked a hole in the center of the dent and used a paperclip to pull the dent out. A small dab of glue seals the pin hole.
pete
Old 17th March 2009, 07:55 PM   #5
Hello Panomaniac, HK26247, and Widman,
Thanks to you all for sharing your experiences! I think I will try make a small hole and fix it from the inside as one of the suggestions said. Thanks!
Best regards
Peter
Old 18th March 2009, 01:46 AM   #6
Alex from Oz is offline Alex from Oz  Australia
Alex from Oz's Avatar
Try the vacuum cleaner idea first.
You will need a hose attachment that is just slightly larger than the dust cap.
1. With vacuum cleaner OFF, place hose over dustcap and hold against the cone.
Make sure you hold the hose still
2. Turn vacuum ON for a few seconds and turn OFF again
DO NOT remove the hose until the vacuum cleaner has stopped.
3. Look and see if the dustcap has been sucked out.
If it is still pushed in, then repeat but leave the vacuum cleaner ON for a bit longer than the first time.
If you still get no joy, then make a hole.
Alex
Old 18th March 2009, 02:28 AM   #7
tf1216 is offline tf1216  United States
Would a large straw with one's own mouth to create suction work? I feel like using a vacuum is a bit dangerous.
Old 18th March 2009, 03:06 AM   #8
Sparky OR is offline Sparky OR  United States
try a dot of crazy glue on a toothpick, hold it in place til it sets, pull out and then you might be able to twist of bend it off.
Wish I'd studied this stuff with as much interest 30 years ago!
Old 18th March 2009, 03:53 AM   #9
peteran is offline peteran  Sweden
Send a message via ICQ to peteran
I doubt you can get enough suction with a straw to pull it out. The vacuum idea should work and depending on the type you may have settings for "powerlevel" in addition to a bypass "valve" on the "handle".
Old 18th March 2009, 04:13 AM   #10
pjp is offline pjp  India
pjp's Avatar
This is crazy ! Leave it as it is.
You'll cause real damage to the driver repairing what is right now just a cosmetic defect.
Help needed: How do I fix a "pushed in" dust cap?Hide this!Advertise here!
What makes an amplifier "bright", "warm", or "neutral"? JohnS Solid State 51 13th December 2009 06:42 PM
DIY "speaker box" ("BOOM BOX"). Help needed. MASantos Full Range 6 2nd September 2007 12:00 PM
My 2-year-old pushed in the dustcaps on my 12" ATCs houstonian Multi-Way 20 23rd May 2007 10:48 AM
design help needed: monopole 15" / 8" MTM open baffle with Manger taloyd Multi-Way 26 26th January 2007 10:53 PM
"TO220 11-pins 2-rows" TraxMaker's library needed for LM3886T Polo786 Everything Else 0 27th June 2006 07:14 PM
