Hello, I want to use an active crossover in my 3 way system for the low/mid separation. The bass wil be a Lambda SB12 (in 125 liter sealed box), the mid is not yet certain, could be Scanspeak, Acouton, Eton or something like that. I want to cross around 150 Hz.
Bass amp wil be a Plinius SA50, mid/high Aleph5. My options for the Xover: 1. the Pass diy Xover (when and if it comes through. I don't think I can wait for the Pass design for more than a couple of months) 2. The tubed Xover of Glassware/Tube Cad: http://www.tubecad.com/articles_2001...ed_Crossovers/ Eg as a 6/18 dB Butterworth at 140 Hz. No level adjustment as far as I can see. 3. The Thel crossover SAW30: http://www.thel-audioworld.de/module/saw/saw.htm Looks very flexibel, but I have no idea how it works (what kind of filter etc). will cost me 420 euro with enclosere. 4. The XM9 kit of Machand: http://www.marchandelec.com/xm9.htm Will cost me $299-$449 plus an extra $120 or so for transportation and taxes. bit expensive. 5. Something from this Duch company: BMM: http://www.bmm-electronics.nl/Product.asp?Product_ID=7 (maybe you have to click the English flag) Not expensive (200 euro), uses NE5532 opamps, only no level adjustment, only a pair of resistors (op potmeter) in the high output 6. Something based on this kit: http://www.snippets.org/filters/crossover.htm What is a good choice? How much does it really matter. Are "tubes" better than opamps for this (somehow it bothers me to put opamps before the Aleph)? I have red something about that a 24 dB LR filter at very low frequenties (below 300 Hz) is not so good. Is that thru??
Is that all there is? |
#2 |
Just to let you know I'm watching this thread.
I need to DIY the XO, and I'm looking at using the ESP XO schematics http://sound.westhost.com/project09.htm , using the RC calculator on the site, and have already bought components for 150 Hz and 5000 Hz XO points - nothing flash, stock 1% MFRs and green chinese film caps, using TL074 as opamps. I am also balking at constructing this monster three way XO on veroboard - it will require two opamps per filter, per channel, and my total including buffers is 20 opamps total (16 for the filter, 4 buffers I also have fewer options in terms of international purchase, customs clearance, etc. The individual crossover modules are also available from Marchand, maybe you can add your own PSU? I also wrote to John Pomann for basic info, and his offer is really tempting, but for the fact that hardwiring will still be involved as the 'PCB' is a vero-type board with generic traces. I know it is a better choice than components I can get locally, but I have decided to build first and then figure out things as I go along. |
#4 |
Check out white noise audio, they have a active crossover also. Thanks Raj |
#5 |
You could use transistors instead:
Active crossovers I made some test-pcbs that could be used for 1st, 2nd, or 3rd order HP or LP. I did it in a real hurry so they are nothing special...made for BJTs but could be used with JFETs with some pin twisting. I'd be happy to send you the layout if you want it. Should be easy to etch single sided if you P2P the grounds. |
#6 | ||||
Thanks for the tips so far.
Also I wonder wether there would be a mismatch connecting a "pro product" to a "consumer electronics product". I thougth the "pro world" uses higer output/input levels (and XLR/balanced of course)?? Or am I seeing gosts here?In that case it might be a temporary solution until the Pass is born Quote:
Anybody has some comments on the Thel crossover? ![]() I know, no English. Its giving me a hard time too.
#7 |
im in the process of building on of these (olny the hi-pass section)
http://members.aol.com/sbench101/Crossover/xover.gif i realise your after a kit. but all the parts are easily obtainable. |
#8 |
#9 | |
I see different Xovers (eg http://www.borbelyaudio.com/xover.pdf , EB-1102/215 and 216, EB-994/113 and so on). Will have to do some more reading on this. Bit expensive though ( a complete kit for euro 695). Quality looks good.
#10 | |
![]() http://www.diyaudio.com/forums/showt...7425#post37425 It's not his latest word, but as good as crossover gets. You might substitute for some new Fets to keep it updated. I'm using that crossover for my subs and it's good. It got good reviews as well.
www.audiosector.com “Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC |
| Balanced active crossover advice | zigzagflux | Tubes / Valves | 6 | 10th April 2007 07:07 PM |
| Moving to triamp, need decent cheap 3-way active crossover and poweramp advice | bikehorn | Solid State | 5 | 23rd November 2006 05:28 AM |
| Need advice on this active crossover(please) | ostie01 | Multi-Way | 0 | 13th February 2006 02:58 AM |
| Advice on active 6 dB crossover | ostie01 | Multi-Way | 0 | 18th December 2005 12:45 AM |
| XVR1 active crossover, discrete active stage | promitheus | Pass Labs | 18 | 22nd July 2002 02:29 AM |
| Page generated in 0.12947 seconds (80.68% PHP - 19.32% MySQL) with 10 queries |
