#11 |
Thanks for that info. Is it based on some Treshold product from 1988. Wow, how about progress
Funny to see so many different opinions om crossovers... Does sombody have any experience with the tubed crossover form Tube-cad. Will the use of tubes give better results then with opamps?
Is that all there is? |
#12 | |
If you look at the latest design from Pass Labs it's not that different, except for more settings
www.audiosector.com “Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC |
#13 |
Okay, not much progress in this field. However I'm really looking for the of the shelf kits here, most of which are using opamps.
But can sombody enlighten me wether using opamps in de Xover is okay or not when you really want to get a good hifi system. For example I'm planning to "modify" my CD player with the LCaudio discrete zapfilter. Now if I use opamps in the Xover, isn't that a litle bit silly. Or is that a very different thing??? So will I be "spoiling" my Aleph5 if I feed it with an opamp based crossover, or is that silly???
#14 |
You might use just a series cap at Aleph's input which will act as a first order filter and use active, third order filter on low pass amp. That's what I'm doing in order to get the best sound quality.
#15 |
Hello Peter, That would mean a first order (6 dB/octave) filter for the high pass I guess. For me that would probably do, because 1 of the options for the mid/high section is using a high end 2 way monitor system (I'm thinking of Von Schwiekert VR1, which is 89 dB/watt).
But how about adjusting the signal levels. Wil a simple potmeter (or some resistors) in the high/mid section do to get things "even"?? (My low (< 130 Hz) section will be a pair of 85.5 dB/watt 12" Lambda units in a sealed box)?
#16 |
I prefer not to adjust anything in a high/mid section. I use an active buffer stage for the subwoofer 3rd order filter (from Threshold) and I make sure that it has enough gain to match the level of mids and highs. I use a pot before that active filter and this is how I adjust the levels.
My crossover is around 120Hz, so the capacitor required in my Aleph X (actually 2 of them for both positive and negative inputs) are 0.22u. I use Jensen copper foil in parallel with 0.022 silver foil cap. Crossovers don't get much better than that.
#17 | |
http://www.welbornelabs.com/rev4.htm Anybody any comment on that crossover. How is the active part (for a 18 dB lowpass around 130-150 Hz)?? Don't know if its available for 230 VAC though. Also a bit expensive. (sry for kicking this ancient topic)
| Balanced active crossover advice | zigzagflux | Tubes / Valves | 6 | 10th April 2007 06:07 PM |
| Moving to triamp, need decent cheap 3-way active crossover and poweramp advice | bikehorn | Solid State | 5 | 23rd November 2006 04:28 AM |
| Need advice on this active crossover(please) | ostie01 | Multi-Way | 0 | 13th February 2006 01:58 AM |
| Advice on active 6 dB crossover | ostie01 | Multi-Way | 0 | 17th December 2005 11:45 PM |
| XVR1 active crossover, discrete active stage | promitheus | Pass Labs | 18 | 22nd July 2002 01:29 AM |
| Page generated in 0.09612 seconds (80.69% PHP - 19.31% MySQL) with 10 queries |
