Old 16th March 2009, 01:33 PM   #1
wigginjs's Avatar
Default Stupid baffle question - Woofer beside tweeter, why not again?
I know that it is a commonly understood design rule not the place the woofer and tweeter horizontally beside each other in a two-way speaker, but why not again? Is it because it generally makes for a wide and thin baffle that requires more baffle-step compensation? What about in the case of an in-wall speaker, does it matter if the woofer is horizontally beside the tweeter? What is the theory behind this rule?
The Four Chairs
DIY Home Theater
Old 16th March 2009, 01:54 PM   #2
Vertical dispersion anomalies are much less worse than horizontal.
Vertical alignment means no anomalies for each horizontal plane.
/sreten.
Old 16th March 2009, 02:53 PM   #3
wigginjs's Avatar
Hmm... So would that also mean that if the listener is sitting off axis horizontally (even slightly) will result in generally poor performance? Should all speakers be toe'd in then?
The Four Chairs
DIY Home Theater
Old 16th March 2009, 03:06 PM   #4
Not poor performance, just not optimal.
Many people don't like how it looks, and don't do it. If your using a grill cloth there's little reason not to offset.
Old 16th March 2009, 04:46 PM   #5
Dr.EM is offline Dr.EM  United Kingdom
Dr.EM's Avatar
Interestingly, the famous Yamaha NS10 studio monitor appears to be designed to be orientated horizontally. At least it nearly always is when I see them.
Old 16th March 2009, 05:16 PM   #6
wigginjs's Avatar
Often with center channel speakers in home theater there is a general rule of not taking a bookshelf and laying it on it's side. Also, there seems to be a consensus that "good" center channel designs will have a T/M on top of each other, with woofers on either side. Why is this? What is the problem with a horizontal MTM?
The Four Chairs
DIY Home Theater
Old 16th March 2009, 06:08 PM   #7
breez is offline breez  Finland
Horizontal MTM has off-axis problems due to interference between mid drivers. A center speaker requires good response over a wide horizontal angle. Vertical MTM in main speakers is not problematic because the required vertical angle is much smaller.
Old 17th March 2009, 01:41 PM   #8
wigginjs's Avatar
So, a horizontal MTM configured as a 2.5way should not exhibit the same off-axis horizontal problems?
The Four Chairs
DIY Home Theater
Old 17th March 2009, 03:11 PM   #9
Possibly so, but then we have the issue of horizontal non-symmetry. How severe this is depends on the design, wanted coverage angle etc. Probably not too bad as rotated 2-ways are commonly used as center channels. Then again horizontal MTM is ubiquitous in the market too! It is best to use a computer software to model the directivity of such configurations.
Old 17th March 2009, 03:51 PM   #10
gedlee is offline gedlee  United States
Directivity is the missing aspect of most designs. Its not easy to estimate and it takes some work to model, but it is the diference between a good system and a poor one.
The vertical MTM will not exhibit "lobes" in the response vertically, but it will be much narrower vertically and both axis will exhibit a response change when the M polar pattern switches over to the T polar pattern.
Open baffle fe127e with BR woofer aliens exist Multi-Way 23 22nd July 2009 04:39 PM
Open baffle headaches! (A.K.A: Spasticteapot is stupid.) Spasticteapot Multi-Way 13 28th October 2006 05:32 PM
Question on Eros MKII tweeter to woofer separation andy2 Multi-Way 2 9th October 2005 04:18 AM
Open baffle Woofer Characteristics Peter Menting Multi-Way 17 22nd November 2003 02:51 AM
Page generated in 0.09600 seconds (79.42% PHP - 20.58% MySQL) with 10 queries
