Cascading Crossovers - Just a Thought. Cascading Crossovers - Just a Thought. - diyAudio
Old 15th March 2009, 09:29 PM   #1
BlueWizard is offline BlueWizard  United States
Default Cascading Crossovers - Just a Thought.
Most of you are familiar with the Dayton Reference series aluminum cone speaker, and you are also familiar with the fact that they uniformly all have a nasty break up and peak in the high frequencies.
So, I had this idea of starting at my selected frequency with a standard 12 db/oct crossover, then just before I reach the break up region kicking in an additional -6db/oct crossover.
Using the 8" Dayton Reference woofer as an example -
http://www.parts-express.com/pdf/295-366s.pdf
So, I would start out, as an illustration, with a 800hz low/mid crossover of -12db/oct. Then around 3khz I would add in another -6db/oct component to tame the break up region.
It was just a thought, but I'm unclear as to what the complication would be, or how to determine the values of the components.
Is this a waste of time? Would I just be better off using a straight forward 3rd order crossover?
In my mind, conceptually, the thought of a cascading crossover seems like a good idea. But again, do I just follow a 2nd order with a 1st order? Do I use the values for a 3rd order at 800hz but change the second capacitor to the value necessary for a 3khz crossover?
At this point, this is all theoretical. I'm wondering if the concept has ever been tried before, and I'm wondering what design considerations I would need to keep in mind if I ever decided to do this?
Too much time and not enough money on my hands.
Steve/bluewizard
Old 16th March 2009, 12:28 AM   #2
Few is offline Few  United States
Years ago I heard through the rumor mill that at least some of the Apogee speakers used a relatively shallow roll-off at the crossover point, and then added further attenuation an octave or two away from that point. I have not verified that, though, so perhaps someone with more direct experience with those speakers can speak with more authority.
Few
Old 17th March 2009, 04:51 AM   #3
Dr. Ram is offline Dr. Ram
Dr. Ram's Avatar
Default Re: Cascading Crossovers - Just a Thought.
Steve/bluewizard
You'd be better off using a "single" crossover of higher order. A crossover's characteristics are not just about cutoff and slope. The "alignment" of the crossover - its ripple/transient characteristics - must also be considered. For example, cascading two Butterworth filters (which have a certain set of characteristics) at the same frequency gives you a LR characteristic (which is different). If the frequencies are spread out really far apart (and 800 and 3k are not far enough) then the sections may be treated as independent. Otherwise the resulting alignment will not have the same characteristics or alignment as the original one, which means that in your case even at frequencies below 800Hz you do not have the same characteristic of the 12 dB section acting alone.
HTH
-Ram
www.audesine.com
Old 17th March 2009, 01:55 PM   #4
I believe part of Apogee's motivation was precisely to take advantage of the better transient response associated with shallow filters while still providing adequate attenuation of frequencies well into the stop band. Clearly you don't end up with any of the "classical" responses (Butterworth, Bessel, ...) this way but it wouldn't be the first time a non-textbook approach worked well.
I'm really dredging my memory here, but my recollection of an interview with Jason Bloom--Mr. Apogee--was that he claimed this approach is used in non-audio applications (for some reason microwave frequencies come to mind but I could be way way off on that) and he was surprised it wasn't more widely used in audio.
In any case, I don't mean to champion this approach. I'm just contributing my recollections in case they help Steve track down more information.
Few
Old 17th March 2009, 03:58 PM   #5
gedlee is offline gedlee  United States
gedlee's Avatar
There is no reason not to do this if it helps. The bottom line with any crossover is what makes it work. The idea that an ideal electrical crossover will be ideal on the acoustic responses of a set of drivers is ridiculous. So if cascading filters makes it work, then do it. I do this all the time. But just remeber that its the final Acoustic response that matters not the electrical response.
However, from a given number of components, you will get more HF rejection from a properly designed third order filter than you will with a cascaded set as you have described. But if it works then do it.
Earl Geddes Gedlee Website
Old 18th March 2009, 07:05 PM   #6
Thank for the replies.
In pure concept, this seemed like a good idea. The one part of it the left me feeling uneasy though was, how do I make sure the filters stay separate and not merge together into a single filter that doesn't conform to either selected crossover point.
As ramkumarr implies, you can't. The capacitance will indeed merge together in a bad way.
In a sense, what I envisioned looked exactly like a standard 18db/octave crossover. It is a T-filter, using the HF as an example, it has a series cap, followed parallel coil, followed by another series cap. Though separated by the coil, we have two caps in series.
Does the coil isolate them so they don't interact? It must to some extent to get a standard 3rd order crossover to work. But I also notice that, in a standard 3rd order, the second cap doesn't match the first. One would assume that you simply cascade three identical stages together to get a 3rd order. But that is clearly not true. Something is effecting the second cap to require a value change.
So, while I still like the idea, I don't see anyway to figure it out logically. So, I'm stuck with cut-n-try, which doesn't seem very scientific, nor very cost effective.
Still despite all my rambling, I do appreciate the responses.
Steve/bluewizard
Old 11th August 2011, 08:34 PM   #7
This is something of a dead subject, but I must admit, conceptually, I still like the idea of a two-stage cascading crossover.
I'm sure I'm creating many more problems than I think I'm solving but what if the standard lower frequency 12db/oct was in the high side, and the higher frequency 6db/oct was in the low side?
Would the speaker impedance isolate the two and keep them separate? Or, in the far more likely case, am I just delusional?
Steve/bluewizard
Old 11th August 2011, 09:38 PM   #8
boris81 is offline boris81  United States
Music and Design - Duelund_and_Beyond
I was just looking at this. It might be of interest.
I'm not an expert but I think a well placed notch filter will work best in your case.
Old 11th August 2011, 10:17 PM   #9
wintermute is offline wintermute  Australia
just another
wintermute's Avatar
That daytons breakup is very nasty! I was going to suggest using a notch filter, but after seeing that curve I'm not so sure. you might need two tuned a bit to each side of the peak, as getting something broad enough would be difficult.
attached is a plot comparing original vs with notch filters and a some what standard 2nd order filter.
Tony.
Any intelligence I may appear to have is purely artificial!
Some of my photos
Old 11th August 2011, 10:20 PM   #10
Jonathan Bright is offline Jonathan Bright  Australia
Hi Blue Wizard.
I have thought along these lines for a while. A good idea and easy to implement.
I think it is useful to start with an appropriate Zobel across the driver. Then insert your first order compensation. Next another Zobel (or "conjugate matching network"....all the rage with Kef 25yrs ago.) That gives you the right termination for the second order cross over....
It sound complicated but its not too bad and the zobels are not expensive as you are only buying a couple of caps and resistors. If the original graphs for the driver are right you can pretty much use standard values from the usual tables for xover/frequency...
Go for it.
Jonathan
"It was the Springtime of the year when aunt is calling to aunt like mastodons bellowing across primeval swamps." P.G. Wodehouse.
Cascading Crossovers - Just a Thought.Hide this!Advertise here!
cascading Q ocool_15 Multi-Way 9 13th November 2009 01:04 AM
I thought I understood crossovers .... MrUnsocial Multi-Way 12 19th July 2005 10:32 AM
Cascading in Crossovers? Gavinator68 Multi-Way 7 8th April 2004 07:14 PM
cascading ttl-counter Papageno Digital Source 0 4th December 2002 04:22 PM
Oversampling / Cascading hill Digital Source 0 21st November 2001 02:07 PM
Copyright ©1999-2017 diyAudio
