Old 15th March 2009, 08:31 PM   #1
Key is offline Key  United States
Default √½ instead of the golden ratio
Do any speakers use it? Any pics?
Old 15th March 2009, 09:00 PM   #2
As far as I've been able to discern there is an Architectural Golden Rule and a Acoustical Golden Rule. I always use the Architectural model because that is what was contained in the first speaker design book I even used.
But is is for visual appeal, not acoustic perfection, though it comes very close to acoustic perfection too.
The rule is simple -
1.4:1.0:.707
If you divide 1 by .707 you get 1.414.
So, the actual ratio is 1.414 : 1.00 : 0.707
The also correspond to trig functions, and are also the SqRt(0.5) and the SqRt(2).
So, a visually appealing cabinet would have the ratios of 14" H x 10" wide x 7" deep, or 24" x 20" x 14".
My cabinets are 26" x 18" x 13", which is slightly off from the ratios at 1.44 : 1.0: 0.722, but I don't think we need to haggle over a few fractions of an inch. The perfect dimensions would be 25.45" x 18" x 12.73"; I figure I'm close enough.
Notice that using this ratio, the depth come extremely close to being a multiple of the height.
Steve/bluewizard
Old 15th March 2009, 10:07 PM   #3
Yeah I had noticed .414 before in other things. I had always thought of it as 22.5 tan though. Same with √½ I always think of it as 45 sine.
My monitors (wharfedale diamond 8.2) I believe use the golden ratio or are close being 364MM x 212MM x 322MM . And if you take a program like Atrise Golden Section you can kind of see how they used it in the placement of the phase plug and tweeter.
I had always used both just as a way to be less cliche than the rule of thirds. It's not used as much as the rule of thirds in photos and designs. But I also notice these numbers come up in dsp and audio processing.
Old 15th March 2009, 11:17 PM   #4
I thought this one was kinda cool for the golden ratio
Diamond 9
the guide is set to golden vertical 1.618034
Old 16th March 2009, 02:02 PM   #5
1.4:1.0:.707
Steve/bluewizard
AFAIK its more like ~ 0.6 : 1.0: ~1.6, if they are x, y,
and z then z/y needs to equal y/x = 0.618 : 1 : 1.618.
sreten.
Old 16th March 2009, 02:15 PM   #6
He was doing √½ not the Golden Ratio.
√½= .7071
Old 16th March 2009, 02:20 PM   #7
Originally posted by Key
He was doing ½ not the Golden Ratio.
½= .7071
comes very close to acoustic perfection too. The rule is simple -
1.4:1.0:.707
Hi, its the Golden Ratio for visual appeal and acoustics, /sreten.
Old 16th March 2009, 03:05 PM   #8
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
I have used 0.7 when 1.618 wasn't applicable due to constrains. It works. Still less ripple on impulse graph than near symmetry. Unfortunately haven't saved any photos. Not as good as with 1.618. Near enough though.
Old 16th March 2009, 03:07 PM   #9
Salas's Avatar
P.S. Better use Edge software. There are many possibilities on a baffle, certainly more than those two.
Old 16th March 2009, 03:22 PM   #10
PigletsDad's Avatar
Default Why the golden ratio?
In some cases, there is mathematical justification for choosing the golden ratio.
If we want the sequences of modes in the two directions to have few near coincidences, we want to avoid a simple rational ratio, but instead want the most irrational one we can get.
One specific way of defining "the most irrational", is to say that it is the number with continued fraction expansion that converges most slowly. Any exact rational has a finite continued fraction expansion over the integers, but for an irrational the expansion carries on. If we want the expansion to converge slowly, we should never divide by a large number. So if we consider
g = 1/(1+1/(1+1/(1 .......
which looks like the most slowly converging expansion possible, then you can show that
g = 1/2 + sqrt(5)/2
Neat, huh?
The Golden Ratio Stage Stee Solid State 7 22nd February 2009 08:46 PM
Golden Ratio Height edjosh23 Full Range 13 3rd February 2009 09:52 PM
W4-1320SB Golden Ratio BR sharpi31 Full Range 4 8th December 2005 09:50 PM
Golden Box Ratio - Important or not? Ornlu Subwoofers 5 27th May 2005 06:52 AM
Golden ratio - Example? icebear Multi-Way 5 17th April 2004 08:40 PM
Page generated in 0.10035 seconds (85.07% PHP - 14.93% MySQL) with 11 queries
