Old 15th March 2009, 05:40 PM   #1
genmin is offline genmin  United States
Default Speaker testing
Just recently have acquired an old speaker and it is testing 12.6 on the multi meter, I suspect it is a 16 ohm speaker. Can I succesfully run this thing out of a guitar amp with an 8 ohm out put and achieve the maximum output of this speaker for testing it to see if it works and how it performs. I just need to check it to see if it is working or not. And would it do the same if it was done with an amp that had a 4 ohm load. I have these two types of amps.
Old 15th March 2009, 05:55 PM   #2
frugal-phile(tm)
planet10's Avatar
16 ohms on an 8 ohm tap won't give max output power wise, but distortion should decrease. It won't hurt anything.
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Speaker Testing Q weinstro Multi-Way 2 13th September 2007 08:37 PM
speaker testing bruce ferrara Multi-Way 0 16th February 2007 03:43 AM
Car Speaker Testing warren o Car Audio 0 30th May 2005 05:08 AM
Amp for speaker testing Baronty Tubes / Valves 0 12th October 2004 09:27 AM
Amp for speaker testing one_happy_hippy Multi-Way 1 17th May 2004 02:31 AM
Page generated in 0.07442 seconds (70.73% PHP - 29.27% MySQL) with 10 queries
