Can somebody tell me if this diode will suffice for D1 through D4?
http://search.digikey.com/scripts/Dk...=568-1362-1-ND http://mysite.verizon.net/tammie_eri...jig2/jig2.html
Building a 2.1 system out of a 3/4"x4'x8' sheet |
#2 |
I would vote to use a voltage divider instead of diodes if you know the voltage gain of the amplifier you use.
Hear the real thing! |
#3 |
you will get much better results and it is very inexpensive and a lot easier to build
#4 |
The diodes are not normal diodes; notice the 'z'-shaped bar connected to the arrow in the diagram.
These are Zener diodes which means they will hold a specific voltage very much like a voltage regulator. In fact, they are frequently used as a reference voltage in a voltage regulator. The diodes in question appear to be 5.1v 1W Zener diodes. This mean any incoming signal over 5.1 volts will be clamped at ±5.1v. This prevents over voltage on the inputs. (Actually, it is clamping at 5.7v, but let's not complicate the issue with details.) Trying to search anything out from Digi-Key is very difficult. However, if you have the printed catalog, it shouldn't be too hard to find a 5.1v 1w Zener Diode. Try this Digi-key part number - 1N4733ADICT-ND ... 5.1v 1w Zener at $.44 each. (page 1282 in the catalog) Keep in mind that the voltage isn't critical. Agian, it is just acting as a limiter or over voltage protection on the input. Likely any thing in the range of 4 to 7 volts would work fine. Steve/bluewizard |
#5 | ||||
like four million tons of hydrogen exploding on the sun like the whisper of the termites building castles in the dust |
#6 |
the lines in are to the sound card input and where the two resistors are to the one op amp input is your calibration resistor and the out of course is from the speaker I modified by using a precision potientometer instead of switch out resisitors
a lot more compact and can use batteries with it like to AA or C, D, or 9v with a regulator package thrown in Correct +3 -1= 2 |
#7 | |
Anyway, my line-in clips at well under 1V. Is there a reason why Wallin likes 5.8V?
#8 |
Q - Anyway, my line-in clips at well under 1V. Is there a reason why Wallin likes 5.8V?
PC sound card chips run at +5V?, maybe he was aiming for 5V initially. So using Vz = 4.3 would be more closer? BWizard has it right check this app note about protecting audio interfaces http://www.onsemi.com/pub_link/Collateral/AND8245-D.PDF
#9 | |
Then the Vpeak across BP3-4 would be 17V, thus allowing me to use 1/4W values for all the other resistors (as long as their values did not change). EDIT: Also, does anybody know why Wallin picked the resistance values that he did? For the voltage dividers, he could've used 1k with 100R and 316R for the -20dB and -10dB measurements. I can see 1.175K and 130.1R, I suppose, but what does the 543.2R R6 do? And for the calibration resistors... well, are 16.2R and 4.05R the recommended resistances to use with SW? EDIT2: So he says that the absolute values for R4 and R5 are not important. Cool.
#10 |
bumpity
| FS: DIY Wallin Jig II for Speaker Workshop | honinbou | Swap Meet | 8 | 27th May 2007 06:46 AM |
| Speaker workshop ? | A_Reef_Scene | Multi-Way | 14 | 28th February 2007 12:39 AM |
| Speaker workshop Wallin jig setup for sale | kingdaddy | Swap Meet | 0 | 7th December 2005 05:05 PM |
| A little Speaker Workshop help | kneadle | Multi-Way | 18 | 25th October 2004 10:12 PM |
| Wallin Jig 1 for Speaker Workshop: Wiring Problem?! | Rarkov | Multi-Way | 1 | 12th September 2002 08:18 PM |
| Page generated in 0.11937 seconds (80.62% PHP - 19.38% MySQL) with 11 queries |
