Old 14th March 2009, 11:17 PM   #1
Henkjan is offline Henkjan  Netherlands
Henkjan's Avatar
Default B&G Neo3 - backcup or backchamber
I searched but could not find it: has anyone posted a comparison of the Neo3pdr with the standard backcup vs with a larger chamber? objective and subjective.. I would like to try the larger backchamber but want to be sure that it's worth the effort
Old 14th March 2009, 11:27 PM   #2
mwmkravchenko's Avatar
Default Well protected by a cup
What you will gain is a bit of efficiency by isolating the rear wave comming off of the driver. I usually use the neo 8 and provide it with a volume that I stuff with dacron fiber. We are not dealing with a diaphram assembly that really needs to be balanced with a given enclosed mass of air in order to function correctly as in a woofer box. It is mostly rear wave isolation that you are trying to accomplish. That being said you can to a modest degree change the lower end of the tweeters response with the stuffing and the size of the enclosure. But in my experiments with the neo 8 which is a larger diaphram than the neo 3 the volume is quite modest. I use around 350 ml .
Mark
Mark
Old 15th March 2009, 02:40 PM   #3
soundchaser001's Avatar
Hi All:
mwmkravchenko;
You have used the Neo8s? Would you mind commenting on the sound/performance? Do you use them as a line source or one-two (MTM)?
I have an idea to use some in a design as monopoles in a short (32") line source for listening in a small room.
Did you get them at Parts Express or have you found a Canadian source? All of the more local sources I have found are home theatre system consultants.
Sorry for all of the questions and I don't mean to hijack the thread.
Matt
P.S.
Probably a very nice day in Perth today. Spring is coming.
Old 15th March 2009, 04:31 PM   #4
Henkjan's Avatar
mmmm... nothing desisive... but backwave isolation is potentially worth trying.. I'll try some inverse horn shaped or triangular shaped backchamber filled with angel hair stuffing (this is made from kevlar type fibres, rather expensive but for such a small volume not a problem)
Old 16th March 2009, 12:46 AM   #5
Default Let's not highjack this business
Hi Matt!
If you want info on sources feel free to send me a private e-mail.
I've been using these drivers for about 6 years. As for performance they are a tough act to beat when used within their proper limits. A poor man's esl would be a good way to put it. They do need a notch filter to some extent on the high end. But they are clean and clear as well as efficient.
I have some right in front of me as a matter of fact. They are going into a large multi-driver two way.
Mark
Mark
bigger backchamber for bms 4550...? taotao Multi-Way 12 3rd July 2009 10:14 PM
FS: BG Neo3 PDR mac Swap Meet 2 29th June 2008 05:40 PM
FS BG Neo3 mitchyz250f Swap Meet 4 22nd May 2008 07:27 PM
WTT: BG Neo3 for BG Neo3-PDR azngotskills Swap Meet 0 1st December 2007 10:24 PM
Pr. BG Neo3 PDR FS Ed LaFontaine Swap Meet 3 2nd July 2005 12:03 PM
Page generated in 0.08704 seconds (74.68% PHP - 25.32% MySQL) with 10 queries
