Old 15th March 2009, 09:03 AM   #11
frugal-phile(tm)
planet10's Avatar
Originally posted by paulfk
thanks dave, so a difference in output should be noticed when rotating the L pad.
That is its whole purpose
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 15th March 2009, 09:21 AM   #12
paulfk is offline paulfk  United Kingdom
dave
and if there is no audible difference?
Old 15th March 2009, 09:28 AM   #13
frugal-phile(tm)
planet10's Avatar
You mean difference in level? Then the L-Pad is broken or wired incorrectly (assumming the tweeter is fine -- you can just hook up the tweeter & the cap to test that)
dave
Old 15th March 2009, 03:31 PM   #14
Speakerholic
Cal Weldon's Avatar
What Dave said.
Next stop: Margaritaville
Some of Cal's stuff | Cal Weldon Consulting
Old 15th March 2009, 05:47 PM   #15
ok, have measured resistance at the binding posts and there is nil. So have dismantled tweeter, removed driver checked resistance 7.2 Ohms, tested L pad between terminals 2 and 3 and got a maximum of 8 Ohms down to zero when adjusting on spindle. Between 1 and 3 I get 7.8 Ohms up to 42 Ohms. Between 1 and 2 I get 7.8 Ohms - 42 Ohms. Can someone advise me on the correct wiring.
Old 15th March 2009, 06:02 PM   #16
frugal-phile(tm)
planet10's Avatar
Old 15th March 2009, 06:12 PM   #17
thanks, that looks like the wiring on the fostex website, however the L pad I have is a monacor AT-62H and shows it as pos from amp - 3, 2 - + on driver, neg on driver to 1 and neg from amp, the opposite of the fostex wiring. I take it the cap goes on the positive side
Old 15th March 2009, 07:38 PM   #18
Speakerholic
Cal Weldon's Avatar
Cap won't matter, it's an AC circuit.
Old 15th March 2009, 07:55 PM   #19
after checking the resistance between 1 and 2, 2 and 3, 1 and 3, it made sense to follow the daves wiring, which is the same as fostex. wired up one cap and attenuator outside the cabinet and tried it out, can now adjust the volume. Wired both supertweeters in the cabs and now waiting for glue to set. Had to glue the attenuator as the spindle will not protrude through the ball shaped cabinet.
166 es-r BLH w/ t90a supertweeter kazoo Full Range 16 17th January 2007 09:26 PM
supertweeter help... one1speed Full Range 12 30th March 2006 09:12 PM
Adding a supertweeter for FR over 10k chuck55 Multi-Way 5 9th November 2005 01:06 AM
Fostex supertweeter KevinTams Multi-Way 15 23rd August 2005 09:03 PM
Good supertweeter? morbo Multi-Way 1 25th September 2004 07:07 AM
Copyright ©1999-2013 diyAudio
