Old 13th March 2009, 03:01 PM   #1
IG81 is offline IG81  Canada
IG81's Avatar
Default Golden ratio boxes - wich sides?
I'm looking to build a sealed enclosure for a 5.5" fullrange with the approximative golden ratio inner dimensions of 11" x 17" x 29".
29" will obviously be the height. Is there a consensus as to which other dimension, depth or width, sould be the second largest?
WinISD gives me width as 17". OTOH, I have often seen depth as the second largest. I can see how baffle step might be affected by this choice. Anything else to think about? Thanks!
Old 13th March 2009, 03:08 PM   #2
badman is offline badman  United States
Custom Title
badman's Avatar
The difference between 11" and 17" for the bafflestep isn't going to be huge. You'll need compensation either way, depending upon placement.
I'd go 11" wide and 17" deep.
I write for www.enjoythemusic.com in the DIY section. You may find yourself getting a preview of a project in-progress. Be warned!
Old 13th March 2009, 03:23 PM   #3
The Golden Ratio tends to be a 1.6 to 1 ratio so that standing waves given off by the driver are diminished as much as possible. With this in mind, the 17" dimension is the width and the 11" is the depth.
Here is a web site calculator that may help you out: http://www.carstereo.com/help/Articles.cfm?id=5
Old 13th March 2009, 06:06 PM   #4
frugal-phile(tm)
planet10's Avatar
Once you have the GR, which side you put the driver on is determined by aesthetic, baffle loss/diffraction, room placement, and whether you are putting a number of drivers on it...
aesthetics is wholly up to you. A classic GR would have you putting the driver on the wide side.
baffle loss/diffraction: the wider baffle (nominal 250 Hz, assuming 19mm walls) will give a lower baffle step, and push the baffle step ripple to lower frequencies and push BS down closer to where you can use wall proximity to cancel BS, the narrow baffle (365 Hz) will have a shorter time till edge diffraction and the box will tend to dissappear more easily. For minimum edge diffraction you'd want to put the driver on the nominal bottom of the box.
BTW: those internal dimensions aren't really that close to golden ratio at 1.7:1:1.65. For a box your desired volume 11x17x29 = 5423 in^3 = 88867 cm^3. Take the cube root = 44.625, you need a box of 72.2 cm x 44.6 cm 27.6 cm (28.42" x 17.57" x 10.86"). i would round off to the nearest 1/8" if working in imperial units.
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 13th March 2009, 06:24 PM   #5
IG81's Avatar
Yeah, I know it's not quite golden. Turns out a 4x8 wood sheet has enough surface to produce all my panels, but they don't all fit on it, so I may have to slightly reduce size and maybe work with real golden ratio. Qtc will rise a bit, it was at 0.74.
Thanks for the input everyone!
Old 13th March 2009, 07:35 PM   #6
Ron E is offline Ron E  United States
Ron E's Avatar
Originally posted by greenmark59
The Golden Ratio tends to be a 1.6 to 1 ratio so that standing waves given off by the driver are diminished as much as possible. With this in mind, the 17" dimension is the width and the 11" is the depth.[/URL]
Oh, is that how it works?
phi=1.61803398874989484820458683436564......
interestingly:
phi^2 = phi +1
1/phi = phi - 1
..and here's some more....
http://www.mcs.surrey.ac.uk/Personal...bFormulae.html
Actually, it does not matter what face you put the drivers on. In fact, these ratios don't do much except give overly type "a" people something to fret about. As long as you avoid (and in most cases even if you don't avoid) duplicate dimensions or dimensions that share a common factor, damping material will take care of the rest.
Our species needs, and deserves, a citizenry with minds wide awake and a basic understanding of how the world works. --Carl Sagan
Science is a way of thinking much more than it is a body of knowledge. --Carl Sagan
√½ instead of the golden ratio Key Multi-Way 19 18th March 2009 09:36 AM
Golden Ratio Height edjosh23 Full Range 13 3rd February 2009 09:52 PM
W4-1320SB Golden Ratio BR sharpi31 Full Range 4 8th December 2005 09:50 PM
Golden Box Ratio - Important or not? Ornlu Subwoofers 5 27th May 2005 06:52 AM
Golden ratio - Example? icebear Multi-Way 5 17th April 2004 08:40 PM
Page generated in 0.09045 seconds (75.92% PHP - 24.08% MySQL) with 10 queries
