Are there any differences in port size (diameter), shape and number?
(if they are all tuned to the same freq as below...)
So one big one (100mm) vs two smaller ones (60mm) vs a slot version
Generally the lower the velocity, the better. I wouldn't trust the vent mach calc in winisd beta. If those vents are all tuned to the same frequency then the shortest vent has the smallest area and should have the greatest vent mach. Winisd pro alpha is a bit better. Unibox (requires Excel) is better than either, IMO.
