Old 12th March 2009, 09:27 AM   #1
Default MLTL with B&C 10PS26 + Seas Tweeter
I have built a pair MLTL speakers with B&C 10PS26 and a pair Seas H1499-06 27TBCD/GB-DXT. (Long name!)
I have just started playing some music through them.
They can realy play some serious bass. They sound very alive and has that solid "feel" to them, the different instruments has their own uniqe body and weight.
Some Hornresp data:
We live in a horizontal world, why use vertical topologies???
Old 12th March 2009, 10:04 AM   #2
I just realised that i totaly forgot the reason I wanted to post here!!
I just want to ask about the MLTL alignment, and how to get a MLTL box optimized.
This is what i came up with after a couple hours of playing with Hornresp and looking at pictures of other MLTL speakers. I placed the driver where the natural cancelation of higher harmaonics was most obvious.
Any thoughts about this design? Any improvements??
Johannes.
Old 12th March 2009, 10:36 AM   #3
Default With the size of you woofers
you will have plenty of bass but your midsection which is the most important and most sensitive range for listening is going to be dead I would definitely suggest some midrange speakers and have the tweeter to the inside for the bass is going over power them to the listen point . If you can afford these http://www.madisound.com/catalog/pro...oducts_id=8176 would be a good choice .
Old 12th March 2009, 10:53 AM   #4
These 10 inch drivers are midbass/midrange drivers. They have a wonderfull midrange. An Fs of 54 Hz and a Qts of 0,29 is the reason for the MLTL. A normal BR box will give quite poor basrespons.
They have a lot of the qualitys of fullrangedrivers in the midrange. A light papercone, high BL, low Qts and high efficiency.
Im sorry if my question is not that clear. I hate writing technical stuff in english. Its the MLTL and its tuning i want to ask about.
The B&C driver and Seas tweeter works very well together. They are active XOd at 2200 Hz Lowpass 6 dB/octave and 4200 Hz Highpass 6 dB/octave. The tweeter has 1,7 dB damping and a couple of dB of Eq to counter the waveguide/CD-horn.
Old 12th March 2009, 10:58 AM   #5
Default so what the the FR Sweep look like
And the stereo field effect
Trnasmission line speakers a very specialized and take time to tune 10 inch I would not be surprized to see a lot of dead spots but you have a better idea of what is going on them me
SEAS 5-tv hf tweeter damianl Multi-Way 23 15th July 2009 12:09 PM
A pair Seas 4 ohm tweeter used by B&O gaborbela Swap Meet 3 17th March 2009 10:42 PM
Most non-sibilant Seas tweeter D.A.R.R.Y.L. Multi-Way 13 29th September 2006 01:59 PM
Page generated in 0.08695 seconds (78.16% PHP - 21.84% MySQL) with 10 queries
