#1221 |
Hey M10,
Check your sim one more time! You say the throat piece is 68,5mm but your faulty sim is done with 65mm length. Because of this you get the wrong flare and angles. I found length was 69mm so no big difference. 375(2441, 2482 etc.) was to be a a permantent magnet knockoff of the field-coil WE594. This one has a longer throatpiece with a flare of 160Hz. For some reason the piece was shortened resulting in the higher flare. For some reason the JBL-techs seems unaware of this as they mention the 2441 being 160Hz in their tech-papers.
Brgds Lars |
#1222 | |
Cutoff is 182 Hz. From the schematic diagram I export the horn data, and it gives the mouth angle. It is 4.67 degrees. Finally we agree Revintage! Regarding the difference between JBL and WE, I suspect that JBL simplified (made cheaper) the construction by removing the snout, but kept the mouth diameter. This drawing shows original construction plans: ![]() Last edited by more10; 3rd October 2011 at 07:02 PM. |
#1223 | |
Your adapter problem has been used as a test case for the horn adapter spreadsheet I developed recently. The attached MS/Word file documents dimensions of the adapter that you need. Unfortunately Excel files cannot be attached to messages here; so the formula used have been documented here as well. Comments as well as additions/corrections to this work are welcome. Regards, WHG N.B., due to the product of parameters m * T being fixed by driver exit diameter and flare slope, the required long adapter length and low fc should enhance LF loading of the horn. |
#1224 |
I have put the data provided into a plot - for comparison. To my uneducated eye it looks a little long, and out of family with Azura and other commercial JMLC horns. My experimentation with conical horns gave long results also.
I have been using curve fitting routines to back predict the existing horn, working out compression instead of expansion. To date all have a point of inflection around 100mm dia where the solution diverges. |
#1225 |
What is the radius r_1 and tangent angle a_1 at the throat exit of the horn you are using?
I estimated A_1 = 6.86 deg @ R_1 = 80 mm based on JMLC-200 horn Horns There should be no abrupt change in profile at the point where horn and adapter are joined. Regards, WHG |
#1226 |
Hello,
Often peole speak of a "Le Cléac'h horn profile". The under-meaning of that is that for a given T, a given Fc and various throat diameters the profiles of the obtained horns should share a common profile. This is not the case, for the obvious reason that for a given distance to mouth, the wavefront shape will not be the same if the throat diameter is a, 2a or na... So the problem to build an adapter for a Le Cléac'h horn of a given throat diameter in order to use a driver having a very smaller exit diameter is not a trivial one. In some cases the adding of the adapter will introduce the profile slope twill loose 1st order or second order continuity and this is IMHO a bad thing. The problem is a bit simpler if the axisymetric horn is calculated for the smaller throat diameter and then cut in order to provide a removable adapter (the wavefront on the membrane of a loudspeaker having a large diameter is lesss well defined also... ) Best regards from Paris, France Jean-Michel Le Cléac'h |
#1227 | |
considering your comments here, what are your feelings on the following situation- A choice between the following- A JMLC profile 350hz horn with a 1.5" throat (7 degree angle at start of throat) meeting to a 1.5" exit driver with a 0 degree exit angle. Or a JMLC profile 350hz horn with 2" exit and a 1 inch long adapter to bring the angle down to 0 degrees in order to meet the driver exit angle correctly. This is a real choice for me as I am looking to buy a 350hz JMLC horn from autotech and meet it with a JBL 2452 driver (0 deg exit angle), but Im concerned about having a 7 or 8 degree 'kink' in the throat.- Would this not render a nice smooth profile pointless to some level? Regards, LBS. |
#1228 | |
Hello lbstyling,
For drivers having an exit angle very different than the throat angle of a calculated hypex adapter, I recommand the use of a quadratic throat adpater. You may find drawing ( page 8) and formula (page 10 )at: http://www.excelsior-audio.com/Publi...WhitePaper.pdf Best regards from Paris, France Jean-Michel Le Cléac'h Quote:
#1229 | |
Hello,
I wrote previously : Quote:
http://www.excelsior-audio.com/Publi...201999-09).pdf Best regards from Paris, France Jean-Michel Le Cléac'h |
#1230 | ||||
Regards, WHG Last edited by whgeiger; 5th October 2011 at 05:24 PM. Reason: Typo |
| Page generated in 0.17276 seconds (84.93% PHP - 15.07% MySQL) with 11 queries |
