Old 31st May 2011, 08:03 AM   #1101
jzagaja is offline jzagaja  Poland
Send a message via Skype™ to jzagaja
I have simulated several pro drivers and this one from STX seems good for this task? I could get better only with a large closed box. Isn't better show combined path at 2m at listening position?
This is 16Ohm woofer so Eg=4V.
Group buy list: http://www.diysoundgroup.com/
Visit us at http://www.horns.pl/
Old 31st May 2011, 08:17 AM   #1102
revintage's Avatar
Hey Jean-Michel,
I guess corner loading is mandantory for this concept as you also recommended that in my 414 project a few posts back? Think this also incorporated an added R that made sensitivity low?
Hey Jack,
Find a driver with lower Mms. This will give you a bandwith so you can go for a 1" inch driver and a smaller horn, like your JMLC-400. What was wrong with the low cost 12" you suggested me? It will not need the high compression the 15" gives together withe the JMLC-200.
Brgds
Lars
Old 31st May 2011, 08:20 AM   #1103
Jmmlc is offline Jmmlc  France
Hello Jack,
The difference of path we indicate in the "combined response" module of Hornresp is not related to the listening distance.
It is the difference of path travelled by the rear wave compared to the front wave. In the case of the Horn Open Baffle the difference of path is roughly a bit larger than the distance between the troat of the horn and the edge of its mouth + some additional.
See attached Hornresp help file related to the combines response.
Best regards from Paris, France
Jean-Michel Le Cléac'h
Old 31st May 2011, 10:17 AM   #1104
revintage's Avatar
Jack,
I just simmed the gdn30-400-8SE and it didn´t sim as good as I remember.
Brgds
Lars
Old 31st May 2011, 10:20 AM   #1105
Yes you need a typical large woofer optimized for OB
Old 31st May 2011, 10:39 AM   #1106
revintage's Avatar
Do you? This is the 414 with 10ohm in series....
Low sensitivity though.
Brgds
Lars
Old 31st May 2011, 10:41 AM   #1107
Uhmm can't we find modern replacement ?
Old 31st May 2011, 10:57 AM   #1108
revintage's Avatar
This is the "El Cheapo" STX with 6ohm! Used the wrong "path difference" before.
Brgds
Lars
Old 31st May 2011, 11:20 AM   #1109
Question remains why we use a half of available JMLC200 mouth area and can we improve performance a little bit with lower cut-off.
Old 31st May 2011, 11:20 AM   #1110
jamikl is offline jamikl  Australia
Default Variable path length due to varying group delay of horn.
Probably off topic here but I would like to ask jmmlc whether the above is taken into account in horn response calculations. I ask because I have been modelling some front loaded horns working off an offset H baffle type open baffle and the results look good. I have used eminence beta 15A in the models as that is what I have and find difficulty in using them.
With two in an H baffle,8"or 20cm deep to the rear and a port opening equal to the H baffle cross section but .01cm deep and the front part of the H baffle about 8cm. deep but closed off to make a chamber with a throat area to the horn of 480 - 500sq.cm, mouth area 5000 - 600 sq.cm depending on profile, results look quite good. The lack of xmax shows up low down. I have modelled path difference as the length of the baffle plus the length of the horn. Is this correct.
This seems, generally to give better results than a bass reflex/horn combination. I suspect that better speakers would model quite well in this type of setup.
jamikl
Page generated in 0.13955 seconds (79.96% PHP - 20.04% MySQL) with 11 queries
