Does placing the woofer above the tweeter effect the crossover in a two-way design?
Old 9th March 2009, 07:52 PM   #1
wigginjs is offline wigginjs  United States
wigginjs's Avatar
Default Does placing the woofer above the tweeter effect the crossover in a two-way design?
I'm in the process of building a known two-way design and I've discovered I'm constrained to placing the woofer above the tweeter. The speaker will be the same, just inverted vertically. Does this effect the crossover? I think not because the baffle size stays the same, distance between tweeter and woofer, driver placement on the baffle with respect to edges in general, but it's now inverted. The tweeter will still be at ear height, but the woofer will now be above ear height instead of below it. Any feedback?
Old 9th March 2009, 07:56 PM   #2
DcibeL is offline DcibeL  Canada
DcibeL's Avatar
Tweeter location on the baffle will have changed quite a bit, so yes it is affected. If the phase alignment of the drivers including crossover isn't perfect, which is often the case with 2-way speakers, then the vertical polar response is inverted.
Use this to simulate Baffle Diffraction:
FRD Baffle Diffraction Simulator
The power of Science compels you!
Old 9th March 2009, 08:01 PM   #3
wigginjs's Avatar
Special case sort of. I should have mentioned this. These are in-wall speakers, so the baffle is flush with the wall of the room. However, even for a traditional box speaker, imagine just turning a small bookshelf speaker upside down and raising it's stand so that the tweeter is still at ear height. The tweeters GENERAL baffle placement has not changed (still same distance from edges, just different edges).
Old 9th March 2009, 08:37 PM   #4
DcibeL's Avatar
For an in-wall speaker in which the entire wall is the "baffle", I would suspect all you have to worry about is off-axis response. If you flip the drivers, the vertical polar response is flipped as well.
Does placing the woofer above the tweeter effect the crossover in a two-way design?Hide this!Advertise here!
suspending a small tweeter in front of woofer for "coaxial" effect? bikehorn Multi-Way 10 5th February 2015 11:50 PM
<AUS> B3S active crossover design - Value woofer suggestions? TheSeekerr Multi-Way 0 25th August 2008 01:46 PM
Tweeter impedance and crossover effect - Wharfedale Evo 30 lastig Multi-Way 1 29th January 2007 02:54 PM
help with woofer/piezo tweeter design secateurs Multi-Way 22 7th January 2005 12:16 PM
