I was working with the ML-TQWT worksheet and something just occurred to me.
For the sake of argument, let's say that the driver is 25% from the "top" of the box and the center of the port opening is 4 inches (100mm) from the "bottom" of the box. Also for the sake of argument let's say that the length of the port tube causes a 90 degree bend in the tube. Let's make the tube long enough so the the tube opening on the inside of the box is near the driver. Would this mean that the driver is now acoustically at the "bottom" of the box instead of the top? Or does it not matter at all where the end of the tube is inside the box?
Any technology sufficiently advanced is indistinguishable from magic |
#2 |
The initial part of the worksheets assume you are defining the internal location of the vent.
#3 |
So... if you needed a long tube where would you locate the end?
#4 |
The driver is still at the 25% location. If the port tube extends up almost to the driver then the port tube is also close to the 25% location. The entrance to the port tube is the important variable in the model of the air in the box, the first part of the worksheet. In the second part of the worksheet, the port tube exit is the important variable.
Hope that helps, |
| Port Location | ERICSPEEd | Multi-Way | 4 | 3rd December 2008 10:50 AM |
| Port location | andy2 | Multi-Way | 1 | 17th October 2005 10:20 PM |
| port location on linearrays | justinc | Multi-Way | 16 | 26th April 2005 03:18 PM |
| MJK worksheets – rectangular port help | sunil | Multi-Way | 3 | 5th February 2005 08:58 PM |
| port location? | joe_daddy | Car Audio | 4 | 18th August 2004 01:38 PM |
| Page generated in 0.07827 seconds (72.17% PHP - 27.83% MySQL) with 10 queries |
