hi guys
i have this boston pro acoustic 6.53 car speaker that i want to convert to monitor speaker can someone help me simulate the enclosure need to mount this woofer? i do not mind if the tweeter is mounted on top of the box. like the B&W http://www.sonicelectronix.com/item_...er+System.html Speaker Size 6-1/2" Design 2-way Component System Peak Power Handling 400 watts RMS Power Handling 200 watts approx. Sensitivity 90 dB Frequency Response 50 - 22000 Hz Impedance (per voice coil) 3 ohms Top Mount Depth 5" cant find the woofer parameters. is the above info help? or an intelligent guess on the enclosure really helps. thanks in advance Erwin |
#2 |
I am no authority on this, but I did a search and there is no reference to using enclosures when installed in a car, such as the door. So I would guess they are meant for an Infinite baffle or very large enclosure.
Hope that helps some... Jon |
#3 |
Do you mean open buffle setup?
#4 |
The short answer is it is more trouble than its worth, car speakers do not like boxes and the crossover is completely wrong for a box, and the dispersion of a "top" mounted tweeter. Large open baffle + subwoofer is the easiest way to use as is. |
#5 |
hi Sreten
can you suggest the baffle dimension? does the tweeter mounted on the top or on the same buffle? TIA erwin |
#6 |
btt
#7 |
Size is not critical, the bigger it is the lower the subwoofer setting. Mount the bass/mid at ~ 0.6 of baffle width and the baffle width down from the top. Mount the tweeter directly above it. The bass/ mid should alo be around 1.6 x the baffle width up from the floor. So hieght is ~ 2.6 x width. There are other ways of doing it, but think about your average door which is ~ 0.7m x 2m, needs 0.2m chopping off, an ~ 0.6m door would need 0.5m chopping off, between these is ballpark. |
#8 |
hi Sreten
this is the guideline i need. thx alot i also read some suggest smaller size buffer width. with guideline that the buffer width is less than 2 times the woofer diameter. claim to improve performance. whats your opinion on this? "Mount the bass/mid at ~ 0.6 of baffle width" does this mean that the driver is mount off axis right? Erwin |
#9 | |
In open baffles baffle width determines bass extension. The drivers are not centrally mounted, they are offset. |
| FS Boston Acoustic T830's | RBauer | Swap Meet | 0 | 21st July 2008 08:11 PM |
| anybody tried http://www.acoustic-dimension.com ? | dcg69 | Parts | 17 | 20th April 2005 07:41 PM |
| info on audio-cube.nl & www.acoustic-dimension.com | i2k92 | Parts | 0 | 12th March 2005 10:14 PM |
| (FS) Boston Acoustic replacement drivers (PSB's also) | feke67 | Swap Meet | 0 | 6th October 2003 10:11 AM |
| Page generated in 0.10810 seconds (81.24% PHP - 18.76% MySQL) with 10 queries |
