I know these mics have been discussed for a bit before. However I was just thinking since we always measure through a laptop or computer nowadays, would it not make sense to draw power through usb? I presume usb +5VDC is pretty clean? would I get any problems if I used the usb +5VDC instead of using a 9V battery? The datasheets point out a nominal voltage of 2V to a max of 10.
Thanks! |
#2 |
Yes
preamp+ADC at USB will be used as well to make it practical.
like four million tons of hydrogen exploding on the sun like the whisper of the termites building castles in the dust |
#3 |
I was hoping the built in preamp in my m-audio transit would be enough.. I don't feel like building a preamp.. mine have all failed =(. I was just going to do a 3.5mm plug and usb hybrid that will terminate in a female 3.5mm plug which is "powered" so the mic will get power..
#4 |
Well, you can just use the mic input on your sound card. That provides a 5V bias automatically. You wire the + on the mic to the tip and ring and wire the - to the sleeve, IIRC.
Our species needs, and deserves, a citizenry with minds wide awake and a basic understanding of how the world works. --Carl Sagan Science is a way of thinking much more than it is a body of knowledge. --Carl Sagan |
#5 |
Yes, the mic input on a computer supplies a 5v bias specifically for electret capsules (as are commonly used in PC mics).
However, regardless of how you power your mic capsule I'd strongly reccomend a good quality pre-amp to go with it. The pre-amp inbuilt on computers is usually of very poor quality, they have a lot of noise and likely distortion too; not ideal for measuring. A good quality pre-amp can be built very simply and a kit like below will make it very easy. You can then hook up to the line input which bypasses the low quality pre-amp: http://www.madaboutsound.com/prod_de...1&sa=cf&ctid=4 I am not certain if this kit could be powered by 5v but somebody can hopefully confirm |
#6 |
well I was using my external soundcard, it is definetly better than my internal sound card, I don't have a line in anywhere so I'm out of that option, maybe I can just plug it in and see how it sounds.. can I measure the 5V by plugging in an interconnect and taking a volt meter to it?
#7 |
Yes you can ...mic input is a 3 wire with a gnd, pre-in, and Vs.
What's wrong with Linkwitz preamp and capsule mods ?
#8 |
I am using the linkwitz mod, but wasn't planning on the preamp.
#9 |
Try these threads:
Few questions about Linkwitz' mic amp circuit http://forums.anandtech.com/messagev...&enterthread=y
Building a 2.1 system out of a 3/4"x4'x8' sheet |
#10 |
Plan on a pre-amp esp if doing the capsule mod. The gain (mic fet) is cut to less than 1 for lower noise and higher spl.
| measuring hum | woodturner-fran | Tubes / Valves | 16 | 7th February 2007 02:28 AM |
| Measuring car amp | sq_guy | Car Audio | 6 | 12th July 2005 11:56 AM |
| how is it measuring? | fumihiko | Digital Source | 18 | 24th January 2005 04:10 PM |
| Measuring Le | thatvan | Multi-Way | 6 | 29th October 2004 10:09 PM |
| Measuring fT and hFE? | capslock | Solid State | 6 | 23rd September 2003 03:50 PM |
| Page generated in 0.09961 seconds (77.84% PHP - 22.16% MySQL) with 11 queries |
