High Efficiency 10" Mid Suggestions
Old 8th March 2009, 08:04 AM   #1
Impious is offline Impious  United States
Default High Efficiency 10" Mid Suggestions
I am on the hunt for a 10" high sensitivity driver for use from approximately ~80hz to ~800hz (rough estimates) in a 2-way system. Relatively limited driver depth is important, really needs to be in the 5" or less area (the less the better). Looking to keep costs low, around $150 or less per driver.
I had been contemplating the B&C 10PS26 which is the driver used in the Nathan 10 kit, but would like some other options to consider.
Any assistance or suggestions are appreciated
Old 8th March 2009, 08:54 AM   #2
Brett is offline Brett
Brett's Avatar
Acoustic Elegance
Try the TD-10M
Very, very nice drivers that will soon be serving in the surrounds in my HT with a WG above and a TD15X below. There were purchased to go into the mains, but then I got my Unity's. I can't just let them sit in the boxes even though they will likely be overkill for the application.
Old 8th March 2009, 12:46 PM   #3
el`Ol is offline el`Ol  Germany
The Eighteensound neodymium 10"ers are quite flat.
Old 8th March 2009, 03:45 PM   #4
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
Dont know any of these
Beyma 10G40, 12G40
Eminence Legend B102, Basslite CH2010
My personal choice will at the moment be the new Eminence Beta-8A
sometimes we know very little, and sometimes we know too much
Old 8th March 2009, 09:07 PM   #5
Thank you for the suggestions so far
Unfortunately the AE & 18 Sound drivers are outside of the budget range I was hoping for.
I'll have to do more research into the Beyma & Eminence drivers.
Old 9th March 2009, 12:31 AM   #6
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
Audio Nirvana 10 with a whizzerextomy?
http://www.commonsenseaudio.com/nirvana.html
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 9th March 2009, 07:23 AM   #7
Brett's Avatar
Many pro drivers are more expensive, or at least in a similar price range.
Try some of the cheaper Eminences or some EV EVM10L which are a decent HE driver.
Old 9th March 2009, 11:15 PM   #8
Yeah, many pro drivers aren't cheap. I was hoping to find some more options in the price range of the B&C driver I posted (B&C seems to be reasonably priced) or find a gem in the Eminence line up with quality distortion performance throughout the bandwidth I'll be playing it. I don't have enough experience with this genre of driver to know which are quality and affordable and which are just "cheap".
dave
Definitely an interesting driver, but I think the whizzer might be a little overkill and with a 1.3" VC and 1mm Xmax....I'm not sure it could hold up to the abuse I intend to put it through
Old 9th March 2009, 11:20 PM   #9
Cal Weldon is offline Cal Weldon  Canada
Speakerholic
Cal Weldon's Avatar
Three choices from Selenium at PE. Tough stuff but the FR might not suit though.
http://www.parts-express.com/wizards...183&srchPromo=
planet10 needs your help:
Let's help Ruth and Dave
Old 9th March 2009, 11:30 PM   #10
boudy is offline boudy  United States
Default P Audio P10/100MB
I've got a set on the way, hope they're groovy.
http://www.loudspeakersplus.com/prod...cific=jofrgrk0
High Efficiency 10" Mid SuggestionsHide this!Advertise here!
Best high efficiency coax - any suggestions? Defo Multi-Way 35 11th July 2009 03:28 PM
High efficiency hi-fi speakers, DIY suggestions? Pirium Multi-Way 52 4th February 2008 05:41 AM
Suggestions for high efficiency high SPL kit/design Kanga Multi-Way 50 23rd May 2003 12:52 AM
Copyright ©1999-2017 diyAudio
