#31 |
Gedlee:
While you are at it, ask a talented local woodworker to make a recommendation on a good blade. There are many types of teeth, and they differ in their set. I had a similar issue a few years ago, and my cabinet making buddy got me a high quality blade that just eliminated the problem. We were working with quartersawn white oak, so I can't say if that will make a difference or not.. It certainly will not hurt to replace your bearings either. Good luck. |
#32 |
My favorite is the Forrest Woodworker II. It's the only one on my saw. (Delta Unisaw) Unless of course the Forrest stacked Dado head is on there.
#33 |
Use a thin-kerf blade and only raise the blade higher than the top of the wood by the height of the teeth. It will keep the blade running cooler which decreases heat warp / wobble which looks and acts like bad bearings. An overheated blade that has cooled down will tend to rewarp next time it heats up when cutting.
Don't rush the cuts, use good sharp blades and ear protection. I agree with S7horton, Forrest makes great blades, Freud too. Ron
"If it doesn't work properly, hope it catches on fire"- Nelson Pass @ BA3 "I fired up the prototype. Literally." The Prophet Pass. |
#34 |
Collectively you have some good advice.
BEARINGS. Wriggle the blade; if it moves the bearings are suspect so replace them. They (99%) are a generic product so just remove the old ones, take them to the local bearing center and ask for a set like this. BLADE ALIGNMENT. The fence should be aligned to the blade or 1/64 slayed away from the leading edge. (0.5mm to the Europeans). The alignment marks on the sawbench are not necessarily accurate. BLADE TEETH. For fine work you need a saw blade with lots of teeth - preferably 60, or even 80 teeth - course blades wth 20 to 40 teeth are for quick rough cutting. Persevere, basic cabinet making is not rocket science. Good Luck Graeme |
| Looking for someone to do a bit of custom woodworking | Glowbug | Swap Meet | 0 | 4th May 2006 11:17 PM |
| Woodworking questions | Vikash | Multi-Way | 13 | 23rd January 2006 08:55 PM |
| need help and info on woodworking | lemans23 | Multi-Way | 13 | 20th August 2005 10:41 PM |
| Woodworking Help! | Xyberz | Multi-Way | 41 | 12th September 2002 03:02 PM |
| woodworking question--please help | Yoda | Multi-Way | 7 | 23rd April 2002 05:29 PM |
| Page generated in 0.07999 seconds (72.88% PHP - 27.12% MySQL) with 10 queries |
